The Best Battery Tender
Old Jan 9, 2011 | 01:16 AM
Brad Grey's Avatar
Brad Grey
4th Gear
Default The Best Battery Tender
I have recently purchased a 2007 FKHTCU which has the Battery Tender pig tail. I was wundering which Battery Tender shoul I get?
My researh came up with this one (the slower the charge the better?)
http://www.batterystuff.com/battery-...W022-0150.html
Old Jan 9, 2011 | 03:52 AM
BirchwhiteHD's Avatar
BirchwhiteHD
http://www.batterystuff.com/battery-.../BM12v117.html
I have 3 of these .....tractor,generator,my bike very happy with them,each comes with a fused harness and the alligator clips,5 yr warrentee
" Excellent unit for slow battery charging and battery storage, and will not overcharge your battery.
The BatteryMINDer is a 3-mode charger/maintainer/conditioner that extends performance and life of all types of 12 Volt lead acid batteries. These include maintenance-free, marine, sealed gel, AGM, dry and valve-regulated batteries."
been pleased so far with them
Old Jan 9, 2011 | 04:21 AM
chappy99's Avatar
chappy99
i just orderd one of e-bay,it's the wildfire battery maintainer,it puts out one watt
and only costs 13.95
Old Jan 9, 2011 | 04:22 AM
bikehe's Avatar
bikehe
The CTEK chargers are a very good product and IP65 rated. I have 2 of them and have been great.
http://www.ctek.com/EN-AU/home/Default.aspx
Old Jan 9, 2011 | 04:25 AM
chappy99's Avatar
chappy99
sorry about that i meant one amp
Old Jan 9, 2011 | 05:05 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Hi,
I use this charger on the Harley because there is a splash proof cap on the connector of the harness:
http://www.gys.fr/spip.php?page=prod...t_id=8&lang=en
I use a cable tie to fix the little connector onto the rear left luggage bar. It sticks out 1.5 inch under the bar.
Old Jan 9, 2011 | 05:18 AM
VTGlideRider's Avatar
VTGlideRider
I have a Delran Battery Tender Jr. If you are only charging the one bike you don't need to go for the higher end models unless you want some of their specific features. You can check their products out here:
http://batterytender.com/
They've worked very well for me.
Old Jan 9, 2011 | 06:40 AM
tallj2000's Avatar
tallj2000
If your bike sits outside that is the one to get. I was looking at getting that one because mine sits outside. That one is waterproof which makes it perfect. If your bike is inside for storage you can save some money and get the cheaper one. If all you want it a tender then these work fine but if you want to charge a weak battery I would recommend getting a charger as well. These will do it if the voltage isnt past a certain point but take a very long time to do it.
Old Jan 9, 2011 | 06:53 AM
tshepherd's Avatar
tshepherd
+1 for the Jr. I have two of them and an older boxy style tender, all work great for keeping the battery alive over a cold NH winter.
Old Jan 9, 2011 | 07:05 AM
robbie52's Avatar
robbie52
I have the Delran Battery Tender Jr on bike, lawn tractor, jet ski, and boat. They work great and cost is reasonable.
