Trouble Code?
Old Jan 10, 2011 | 10:53 PM
jwhacks's Avatar
jwhacks
3rd Gear
Default Trouble Code?
Doing some radio-related work inside the fairing of my 02 FLTRI. When ignition is switched on I get no fuel gauge reading, check engine light is on, low fuel light is on, and won't start. Just doing a stereo unit and speaker replacement and it's been pretty straightforward.
Have checked the low fuel module plus (under the fairing) and the fuel level sender connector (under the console) but they look ok. The shop manual says with the check engine light on I should check for a trouble code but before I go through that any ideas on what could cause the problem? Does a trouble code need to be cleared somehow before it will start?
Old Jan 11, 2011 | 12:32 AM
dawg's Avatar
dawg
Yes
There's the problem
Not to be a smartass, but go back and check all your wiring, etc. or whatever you touched. Something probably unhooked or rubbing, etc.
sporty87
Dec 22, 2015 12:33 PM
Fedoraman
Dec 14, 2013 05:17 PM
05springerclassic
Jul 15, 2013 03:07 PM
berkeydave
May 20, 2012 07:44 PM
keith kaupp
May 29, 2010 07:04 PM
