Lean Angle
Old Jan 17, 2011 | 07:37 AM
jw3's Avatar
jw3
Default Lean Angle
What is the correct or proper lean angle for an FLHT ? I am hoping someone out there is a TECH that can clear this up. I lowered my FLHTK (2010) about 1 inch (front and rear) and the 'lean' of the bike seems - not enough. I am really careful where and how I park. Before I go spending bucks to see what works, what should the lean angle be to maintain a safe/stable parked stance (as compared to 'stock' ?
Old Jan 17, 2011 | 08:27 AM
dawg's Avatar
dawg
2010 FLHTK
Lean Angle (per SAE J1168):
* Right: 33°
* Left: 31°
Old Jan 17, 2011 | 08:41 AM
badknees's Avatar
badknees
I did the same on my FLHTK and your right about how to park it. I'v looked everywhere to find a 1" shorter jifffy stand to no avail. Seems I might have to get it heated and reshaped.
Old Jan 17, 2011 | 08:54 AM
Jackie Paper's Avatar
Jackie Paper
Not sure about yours but there is two jiffy stands for mine since there is an SE model in my bike family. I have both. Dawg is talking about another type of lean angle I think. You need to fix it or really watch were you park it. As is, if a tire was to go down it probably would go over. My SE stand is same appearance but with just a more acute angle. Actually a lot more and bike goes way over with it, almost like the bikes back in the 50-60's
Old Jan 17, 2011 | 09:03 AM
piasspj's Avatar
piasspj
If I remember correctly the early '09 bikes had a shorter stand and the bikes leaned farther over.
I wonder if that was the same stand as earlier years.
Old Jan 17, 2011 | 09:32 AM
MarineBagger's Avatar
MarineBagger
When I had my Fatboy I lowered the carp out of it and needed to change the angle of the kickstand, so I bought an aftermarket wedge type shim that bolted under the kickstand at the frame to raise the stand a bit to give the bike more lean. I used it for years and it worked great. Doing a quick search I found this one at axiom cycles. May or may not fit your bike, but I'm sure there is one out there somewhere that would fit. http://www.axiomcycles.com/pages/ite...temsection=103
Old Jan 17, 2011 | 03:45 PM
hockey8787's Avatar
hockey8787
I would think that the street glide stand would work fine because they are lower than an ultra! just my .02
Pgh-mike
EVO
36
Aug 28, 2016 02:29 PM
Grouser62
Jul 20, 2016 03:03 PM
Assmans
Oct 27, 2011 12:39 AM
BigBrainBob
Mar 17, 2011 04:46 PM
sfetty
Jul 12, 2010 08:13 PM
