Headpipe Reviews
Old Jan 31, 2011 | 07:16 PM
  #61
'05Train's Avatar
'05Train
Originally Posted by fuelmoto
The stock crossover pipe is designed this way specifically to allow maximum exhaust convergence from the right hand outlet. The stock mufflers are also chambered differently left and right. Our Jackpot 2/1/2 head pipe uses this same principal however our design and merge collector flows and scavenges more efficiently
So does that mean that you replace that small crossover, or does your header design mean that it's not an impediment to flow?
Old Jan 31, 2011 | 07:18 PM
  #62
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by smat45
Jamie...
Will the stock heat shield fit the new 2/1 complete system?
<<<We will no longer be offering 2/1 replacement head pipes, we are going to focus efforts on our new 2/1 complete system which will be released this spring.>>>
smat
Our new Jackpot 2/1 full system will include full stainless steel heat shields with a mirror finish
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 31, 2011 | 07:26 PM
  #63
fabrik8r's Avatar
fabrik8r
Let me guess, the new 2:1 system has a larger collector
Old Jan 31, 2011 | 07:30 PM
  #64
smat45's Avatar
smat45
Jamie
I should have also asked...
What year(s) will this fit? I have an 08 SG.
Thanks for the quick reply.
smat
Old Jan 31, 2011 | 07:32 PM
  #65
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
We use the stock crossover with our pipe as well, as noted earlier this allows for maximum exhaust flow from the RH exit and we are maintaining as much velocity as possible. When we were testing pipe design we tried everything from opening up and enlarging the crossover pipe to reducing the flow and nearly blocking it off. It comes down to a fine balance between the collector design and the flow on the outlet side, the stock crossover is incorporated with our overall design and works very good in this application as well
Old Jan 31, 2011 | 07:42 PM
  #66
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Yes our new 2/1 features a large 65mm merge collector
Old Jan 31, 2011 | 07:45 PM
  #67
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Jamie
smat
We plan to offer 2/1 systems for 2009-2011 models as well as a pipe to fit 1999-2008 bikes
Old Jan 31, 2011 | 08:04 PM
  #68
07custom's Avatar
07custom
I'll take a 2-1-2 for an 07 Ultra!
Old Jan 31, 2011 | 08:35 PM
  #69
rk10's Avatar
rk10
wachuko, yes, you can just replace the headpipe and keep your stock mufflers to get rid of the heat, there are people on here that know more than I do, but I believe the bike would also have to be "tuned" for the new headpipe minus the "cat".
Old Feb 21, 2011 | 11:59 AM
  #70
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Our Jackpot 2/1/2 head pipes are now available with a proprietary 2 process internal/external HTC ceramic coating. All of our head pipes are constructed from aerospace grade stainless steel, they are 100% built in the USA, and feature a lifetime warranty. Here are a couple pictures
