Installed Vision today
Old Jan 24, 2011 | 11:38 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
what year models is it applicable to?
Old Jan 24, 2011 | 12:14 PM
Rageous's Avatar
Rageous
bump
RK14SGS's Avatar
RK14SGS
Default needs auto tune for sure
Originally Posted by 03dragonRK
Auto tune is not available yet for the Vision, but I am considering it.
If one has no tuner, this seems to be an ideal unit. However it still seems limited as of now without wide band oxygen sensor feedback to self tune.... am I missing something? I would like one, but it will be a while until auto tune is available in my opinion... making ve table changes is necessary in the stock ecm strategy, but without feedback in closed loop, how accurate will it tune? Looks awesome and easy enough to use over a racetuner or other units though...
Old Jan 24, 2011 | 12:33 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Power Vision works on all 2001-2011 Delphi EFI equipped Harley models except 2011 Softail which will be released slighly later
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 24, 2011 | 12:39 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
AT 100 is already integrated as an active channel in Power Vision, they are simply finishing up the PV Auto Tune Pro tuning app so it will not be long, I should have a more specific timeline when I meet with them in 2 weeks. The PV calibrations also offer adaptive closed loop operation on factory O2 sensor equipped bikes as long as you set the AFR/Lambda table for closed loop. If we have a close calibration for a given setup this will be very accurate.
Old Jan 24, 2011 | 01:50 PM
03dragonRK's Avatar
03dragonRK
Jamie,
Will the wide band O2's be available in 12mm to work on stock headpipes?
Old Jan 24, 2011 | 04:34 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
DRAGON,
Cool, looks like it was pretty easy to install. Once, all the snow is gone, please keep us all posted on the PV and how you like or dislike the turner.
Looks like a Power Vision maybe in the future for me as well.
Thanks for posting!
YELLOWBIRD
Old Jan 24, 2011 | 04:47 PM
RK14SGS's Avatar
RK14SGS
Default Price for AT 100 option
Jamie- how much will the AT feature and dual wide band O2 sensors add to the $499 cost? Thanks
Old Jan 24, 2011 | 04:51 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Jamie,
Unfortunately 12mm wideband sensors are not available. If you have a 2010-2011 Touring to use the AT-100 with Auto Tune Pro you will either need use a headpipe which accomodates the 18mm sensors, or you can add them to your current pipe.
Old Jan 24, 2011 | 04:52 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
The AT-100 is $299.00 thru FM and there will be an extended CAN cable that will be required as well.
