Problem with Kuryakyn TTS Tuner
Old Jan 23, 2011 | 02:28 PM
timinfla22's Avatar
timinfla22
Default Problem with Kuryakyn TTS Tuner
I took the plunge and purchased the Kuryakyn TTS tuner for my bike.
So far as I know, it is a stock bike aside from the K&N filter and aftermarket slip-on exhasut without baffles which were installed by the Previous Owner.
Traditionally, I'd get about 170 miles to the tank but upon a suggestion from a friend, I removed the stock air box and I saw my fuel mileage decrease to around 130 mi/tank.
I figured I must've allowed it to breathe more than the ECU was prepared for when I removed the air box, so I figured I'd get a tuner.
I can download my stock setup, upload any of the pre-configured setups and it all works fine until I try and collect realtime data with something called VTune.
When I try and record VTune data, on the Histogram, all of my indicators turn green except for the AFR. AE, DE, and both F and R O2 Activity shows green - however the yellow WAITING window never changes to green GOOD and the AFR window remains yellow.
If anybody knows, please let me know how to fix this. I've sent an email into Kuryakyn tech support. Hopefully they'll get back to me...
Thanks,
Tim
Old Jan 23, 2011 | 02:33 PM
BadPiggy's Avatar
BadPiggy
I don't think you're going to get much info out of Kuryakyn.
They're just a distributor.
Email/call TTS.
http://www.mastertune.net/
Old Jan 23, 2011 | 02:59 PM
timinfla22's Avatar
timinfla22
ah, sweet - thanks BP! I appreciate the heads-up.
-Tim
Old Jan 23, 2011 | 03:13 PM
fxlowboy's Avatar
fxlowboy
on the upper left corner be sure that the
Big twin ve setup is on
Old Jan 23, 2011 | 03:14 PM
Lonewolf176's Avatar
Lonewolf176
You have all the afr cells maxed on your installed map? Also the engine temperature must be at least 165 degrees before it will record data. The other thing to check is the radio button is set to Big Twin VE Setup, assuming your bike is a big twin.
Old Jan 24, 2011 | 05:33 AM
Grillfish's Avatar
Grillfish
You can also follow the TTS sticky by clicking below. It has a ton of info that might help.
https://www.hdforums.com/forum/elect...ation-194.html
sorensentyler
Oct 8, 2017 09:32 PM
Ron C
Jul 11, 2013 08:14 PM
purpledeuce
Sep 9, 2012 10:03 AM
useR 564357348
Exhaust System Topics
Jul 23, 2011 09:14 PM
arachman
Aug 7, 2007 01:00 AM
