NIM wiring ??
Old Jan 30, 2011 | 09:01 PM
Shark Ride's Avatar
Shark Ride
Default NIM wiring ??
I've installed a NIM with a Road Tech zumo 660 on my 09 Road Glide FLTR. I've seen several posts that state when connecting the 5 wires from the NIM wiring harness that #4 and #19 need to be switched. The instructions state red/blue wire terminal into cavity #4 and the tan/blue wire terminal into cavity 19. I've been reading that's incorrect and needs to be red/blue - into #19 and tan/blue - into #4. Any input, confirmation or rebuttal would be greatly appreciated. I'd like to know before I reattaching my fairing?? Thanks
Old Jan 30, 2011 | 09:37 PM
hdramon07's Avatar
hdramon07
What is the revision date on your instructions? I did the install on my Ultra, & the date on my sheet was 2010-09-14. Everything seems to be working correctly, although some of the pins are for the iPod Interface, & that is where some have had problems. I did not install the iPod interface.
If your instruction sheet is dated 2010-09-14, you're probably good.
Let me know if I need to list the pins/colors from my sheet...
Old Jan 31, 2011 | 12:00 AM
Harleypingman's Avatar
Harleypingman
These are the correct instructions dated 9/14/10
http://www.harley-davidson.com/en_US...ts/-J05169.pdf
Carl
Old Jan 31, 2011 | 09:33 AM
Shark Ride's Avatar
Shark Ride
Carl, Thanks for the attached instructions. Mine are dated 6/10 and are different. I'm going to try a Harley tech line to get a clarification on what is accurate. I can't believe how messed up there tech info is when buying Harley branded product. As a do-it-yourself guy it's hugely frustrating but I can see why the dealer charges so much --- The consumer is paying for the service technician's learning curve. That's just craziness and quite frankly unacceptable!
Old Jan 31, 2011 | 10:18 AM
Shark Ride's Avatar
Shark Ride
Rev 2010-09-14 is the most recent and per Harley customer service accurate. Thanks again Carl -- Looks like I'll be changing several wires and then buttoning up the project.
5280Ruffian
Audio Systems
May 6, 2018 09:45 PM
DAMRK
Audio Systems
Jun 7, 2015 11:45 AM
Munkee
Audio Systems
43
Aug 16, 2014 12:22 AM
kevjud
Oct 13, 2013 05:51 PM
markvarg
Audio Systems
Mar 7, 2011 07:37 PM
