Top End Noise
Old Feb 2, 2011 | 09:42 AM
hdultraclassic2000's Avatar
hdultraclassic2000
3rd Gear
Default Top End Noise
is it common to hear more top end noise like a tappet or lifter when you have a stage 2 cam set up on vtwin....it goes away alittle when is hold the throttle at 3400 rpm...but i can also hear it at 20 to 50 mph.....not at idle though.
Old Feb 2, 2011 | 10:24 AM
my67pnycar's Avatar
my67pnycar
Welcome to the forum. If the noise does not sound like its fixing to fly apart, yes its normal. Its a harley and has engine noise. If you are new to the harley world, get used to that answer " Its Normal". Was the work recently done to your bike or did you purchase it that way? If it a previous modification, it might be a good idea to have the bike looked at by someone who knows whats up.
Old Feb 2, 2011 | 10:41 AM
nwbikerid's Avatar
nwbikerid
As long as it's not rattling loud, then yes.
Old Feb 2, 2011 | 10:42 AM
mikecourthd's Avatar
mikecourthd
Well put my67pnycar. I am on my first Harley and it took me some time to get used to that answer also. I have a similar noise but it runs great. Welcome to the forum.
Old Feb 2, 2011 | 11:36 AM
hdultraclassic2000
3rd Gear
thanks fellas.....great info...and more peace of mind...this is my second Harley...my first was an anniversary sportser with drag pipes only no upgrades....my electraglide has a pwr cmndr, V&H pipes and stage 2 cam setup, runs great..although i do get a popping noise when i let off the throttle....exhaust popping..everytime...it does run rich, so i'm assuming the commander might needs to be remapped...or adjusted to run leaner.No intake or vacuum leaks, other than that i'm very content with it.
SportsterRider85
Aug 26, 2017 03:14 PM
JONNIEROCK
Dec 30, 2013 06:35 PM
SeniorChief56
Apr 8, 2012 07:28 AM
1peter
Jun 5, 2009 11:10 PM
dontdropit
Jan 21, 2009 05:15 PM
