The mods are not necessary, but after you own it a while you will probably be tempted to add things to better suit your needs. I added highway pegs, seat mod, and backrest for creature comfort. I live in the desert where the temp stays over 110* for days on end, so I added SE Stage 1, PC-V, Jackpot Slip-on's, and Harley oil cooler to get my bike to run a little cooler. I added a cup holder and luggage rack for my tour pack for traveling. I'm not even close to being done. You will most likely add a few things as time goes on.
So, let me explain. I am picking up a 2009 RKc with under 500 miles and it is pretty much brand new. It also completely stock. This is my dream bike and a serious upgrade from what I was riding - a 750 Shadow.
I get that many change out exhausts and cams and such like for more power and better sound....but, man, look at where I'm coming from here. I should be OK with power, ride, and sound.
However, are there necessary things that I NEED to do that would be better for my bike?
Thanks.
IMFletcher
You don't need to do anything but fill the tank and ride...
That being said, you likely will make changes that affect performance or aesthetics or both.
I could go over this with a hundred mods but whatever floats your boat. It is all in the chaching you are willing to spend. Exhaust, chrome lowers and at least 20 other things would be on my priority list. It is yours so have fun and do what you want...
You will need to be comfortable on the bike. At the very least, you should be able to spend a couple of eight hour days in a row on the bike, with stops for gas and lunch. If that is torture, then you need to change things. Most common are seats, highway pegs, backrest and bars. If you have a passenger, she will appreciate a backrest.
Some folks are comfortable enough with the stock set up. Give it a try. When something starts to hurt, consider changing it. Go slow and make sure you get what you want.
There are always slightly used seats in the forum classifieds, mainly because one size does not fit all. It's a good way to try a seat without much downside. If you buy used, you can usually get a good chunk of your money back if you have to sell it because it doesn't work for you.
