jack question
Old Oct 6, 2006 | 10:26 AM
FLHT's Avatar
FLHT
Default jack question
Where do you guys position your jack under the bike for the best balance. Or do you set it a little heavy towards the back and strap the front
Old Oct 6, 2006 | 11:31 AM
MACK's Avatar
MACK
Default RE: jack question
what you are doing will work. i let the left leg of the jack go between the riges of the crossmember or right in the middle of that bar. it is a pretty good balance if not jacking too high.
Old Oct 6, 2006 | 12:42 PM
bountyhunter's Avatar
bountyhunter
Set the rear jack beam in FRONT of the frame crossmember....have never used a strap....put the jack in from the left side....works best for me!
Old Oct 6, 2006 | 05:51 PM
billk's Avatar
billk
What he said.[sm=groupwave.gif]
Old Oct 6, 2006 | 10:14 PM
wedgewood1's Avatar
wedgewood1
I use the craftman series jack, but the crossmember is to narrow. So the jack sets on the ridges of the crossmember and the front frame tubes. I use one strap through the transmission area. I have to go from the right side with the jack, and one two-by-four of wood under kickstand so that I can slide jack through. This works good for me when I wash the bike, and I just got done replacing the back tire. 06 Ultra Classic
Old Oct 6, 2006 | 11:40 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
I use the Kobalt lift, got it from Lowes. Roll it under from the left side with the bike resting over on the side stand. The rear jack beam goes inside the the frame cross member. Stabile and well balanced, no straps.
Rengnath
Feb 10, 2018 01:21 PM
Wulf
Aug 13, 2013 06:46 PM
KEVFLHX11
Jun 29, 2012 09:23 PM
rookiedan
Aug 6, 2008 11:30 PM
JBaker421
May 30, 2007 03:40 AM
