Revolution Performance EMS
Old Mar 30, 2011 | 06:06 PM
  #31
mtclassic's Avatar
mtclassic
Originally Posted by Fire-Medic
Which is what made my decision easier and I just went with the Power Vision unit instead.
Mine too, I bought a TTS mastertune. That and I did not want to mess with changing my head pipes to 18mm bungs. If I were wealthy no doubt the EMS would be the way to go.
Old Apr 4, 2011 | 02:29 PM
  #32
StrGlide's Avatar
StrGlide
Latest part numbers from Drag Specialties for the Revolution Performance EMS
DRAG PART#____DESCRIPTION ________________ NOTES_______________________
1020-1366_____EMS PRECISION 04-5 SOFTAIL
1020-1367_____EMS PRECISION 06-10 SOFTAIL
1020-1368_____EMS PRECISION 04-5 DYNA
1020-1369_____EMS PRECISION 06-10 DYNA
1020-1370_____EMS PRECISION 04-6 FLH
1020-1371_____EMS PRECISION 2007 FLH
1020-1372_____EMS PRECISION 2008 FLH
1020-1373_____EMS PRECISION 2009 FLH
1020-1374_____EMS PRECISION 2010 FLH_______REQUIRES 18MM O2 BUNGS IN EXH
1020-1526_____EMS PRECISION 2011 FLH_______REQUIRES USE OF AN 08-10 ECU (temporary issue)
Old Apr 4, 2011 | 03:25 PM
  #33
fxlowboy's Avatar
fxlowboy
Drag specialties $799.00 I paid mine $150.00 less from Fuelmoto
Old Apr 9, 2011 | 08:18 AM
  #34
fxlowboy's Avatar
fxlowboy
Rev Perf receive my ECM on monday... wednesday the ECM arrive at home fast shipping i live in Québec,Canada.
install everything start the bike the first minute the bike run like sh..t but after that everything run smooth ,no more rough idle and good throttle response.i go for a 75 miles ride everything run smooth no more ping the bike run strong quick throttle response,after my ride i check the plug and they look fine nice tan color
So far so good :-))
my first impression wowwww....
next thing is to check the MPG
Old May 6, 2011 | 01:11 PM
  #35
Steakman's Avatar
Steakman
Stage I
Just got mine back today and installing on my 08 SG. Just did a 107" kit with K&N A/C, Andrews 67H cams, V&H Pro Pipe HO, 1.90 valves, stiffer springs and a porting job. Will post results in a few miles.
Old May 6, 2011 | 02:27 PM
  #36
Garcou's Avatar
Garcou
Should throw some real good numbers
Old May 18, 2011 | 06:56 AM
  #37
CoastlineAmps's Avatar
CoastlineAmps
I just ordered one yesterday for my 2009 FLHP 103". Everything stock so hopefully some improvement will be noticed right away. I wanted to get the tuner before all my upgrades.
Old Jun 21, 2011 | 08:06 AM
  #38
RK14SGS's Avatar
RK14SGS
So anyone notice the throttle lag is now gone?
Old Jun 21, 2011 | 08:50 AM
  #39
CoastlineAmps
I finished my install and first full tank ride. Real big change in throttle response. My throttle lag is gone and my bike runs so much smoother....
Old Jun 21, 2011 | 01:45 PM
  #40
RK14SGS's Avatar
RK14SGS
Default mods- RP EMS
May I ask what bike you have, and what mods you have? Was there a different tuner before the Rev Performance EMS, or are you coming from a stock set up? Trying to understand what your baseline was prior to install. Thanks...
