Changed mufflers, should I re-map?
Old Oct 7, 2006 | 10:47 AM
Anthony8858's Avatar
Anthony8858
Default Changed mufflers, should I re-map?
I've had a V&H true dual exhaust system with Oval slip-ons and SE air filter on my bike with a PCIII.
I recently swapped out my V&H Ovals for the stock mufflers. Everything else stayed the same.
Should I make any changes to my map?
Does the bike typically run richer / leaner with stock mufflers over the V&H Ovals?
Old Oct 7, 2006 | 11:00 AM
MACK's Avatar
MACK
Default RE: Changed mufflers, should I re-map?
SEE HOW IT RUNS. BEST TO REMAP AS THE MUFFLERS WILL SIGNIFICANTLY ALTER THE TUNE.
Old Oct 7, 2006 | 11:03 AM
Anthony8858
Bike seems to run normal.
But things aren't always as they appear.
Does the added back pressure of the stock mufflers make the bike run a bit richer than the V&H Ovals?
Old Oct 7, 2006 | 11:16 AM
rhinoevans's Avatar
rhinoevans
Why are you going in the opposite direction of most? And yes , I would think a new map (dyno) is in order. I have the V&H ovals, and want to go with the dresser duals. I was thinking I could add them without a new MAP, but I am not sure. Seem to me like a rather insignificant change.
Old Oct 7, 2006 | 11:23 AM
Anthony8858
I went backwards because my morning ride keeps waking up my youngest daughter. My wife asked me if I would put the stock mufflers on until she starts sleeping better.
Starting that bike in the garage at 6am could be shocking!
Old Oct 7, 2006 | 12:28 PM
bob2002's Avatar
bob2002
I have a 07 ultra with the true duals and the terry fuel/air system and stage one air cleaner,I tried staying with the stock mufflers and because of the design of them IMHO its not a good mix,I went with the screaming eagle touring mufflers(80463-06) which are not loud and sound great and REALLY made a difference in the way it runs.
Old Oct 7, 2006 | 12:35 PM
Mac57's Avatar
Mac57
ORIGINAL: Anthony8858
True enough! Last Sunday morning I started my bike at about 7 AM to go on my HOG chapter's fall foliage run. The next door neighbors have three little ones. My bike has SE slipons. I keep my bike in a CycleShelter between our homes. Tried to start up and leave as soon as possible keeping the revs down. Well two of the little tykes were standing up in the front bay window of their house all smiles and waving at my wife and I as we pulled away.........of course their parents WERE NOT. I think we are still on speaking terms though.
I would think you would have to re-map, but if the bike is running OK I'd just leave it alone.
Old Oct 7, 2006 | 01:02 PM
Anthony8858
Yeh, the little ones waking before Mommy could cause a hazardous condition for me.[&:]
As far as the map....Well, I'm a little lost on this one....
Here's why:
When I installed the V&H True duals, with Oval slipons, I simply uploaded a map from the PowerCommander website, added a little fuel in the 0% throttle to eliminate some popping, and I was on my way.
In this case, there obviously is no map for my true dual / SE air filter and stock mufflers, so I don't have a starting point like I did before.
I guess if I could establish whether or not Ovals run leaner than stock because of the back pressure, I could then reduce some fuel to compensate.
Old Oct 7, 2006 | 01:47 PM
2005UltraNC's Avatar
2005UltraNC
Stock exhaust runs richer than free-flowing pipes (i.e. virtually everything else) - this assuming no map changes. i.e. your ovals ran leaner than the stock pipes.
Old Oct 7, 2006 | 02:43 PM
Darryl88's Avatar
Darryl88
my bike doesnt show up for another couple of weeks. Its getting a stage one kit before I pick it up. VH oval slip ons. Is there that much diffence in the noise between stock and vh slip ons???
