Battery Issue
Old Feb 13, 2011 | 07:13 PM
Alan7407's Avatar
Alan7407
6th Gear
Default Battery Issue
I ride an 08 Ultra Classic, pure stock, and live in So. Cal, so weather is really not an issue. Charging system works fine.
My battery seems to go dead if I don't ride every few weeks. I replaced my battery with a Deka about 3 months ago.
When just sitting, I measured that it draws 110 millamps, which seems acceptable to me, but I don't know what it should be.
Do I have a battery issue or a drain issue ????
Old Feb 13, 2011 | 07:24 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
ive heard the security system takes a small draw,living in wisconsin got me into a battery tender jr. around 20$ i use it year round not just for storage,been getting 5 years or better from batteries.
Old Feb 13, 2011 | 07:28 PM
krazy3's Avatar
krazy3
It shouldn't go dead in a couple weeks, IMO. I don't have security, but even if I don't put the tender on mine for weeks here in Central Ill. where it can get cold, my battery doesn't go dead.
I got 8 years out of an HD battery with no battery tender.
Old Feb 13, 2011 | 07:29 PM
mkguitar's Avatar
mkguitar
security, radio...
trickle charge it when it's sitting.
BTW discharging a battery 100% reduces it's potential capacity by 50%....an early death.
Mike
Old Feb 13, 2011 | 07:31 PM
1flhtk4me's Avatar
1flhtk4me
I would say with a good battery and your location,3 weeks should not be an issue.
I would find where the currant draw is coming from.
I have left my bikes sitting that long at times without any problems.
Have you checked the battery terminals and grounds for corrosion and loose screws?
Old Feb 13, 2011 | 07:35 PM
Fathead2003's Avatar
Fathead2003
Check your charging system when the bike s running. See what the voltage is at the battery terminals. Should be greater than 13 volts or better.
Old Feb 13, 2011 | 07:43 PM
blusmbl's Avatar
blusmbl
At least for cars, 110 mA is not acceptable- that is enough to kill a battery over a week. 50 mA is the bare minimum, and I would expect it to be lower for motorcycles. I think the spec for most jap bikes is in the 5 mA range or lower.
I'm too lazy to go look this information up in the service manual, though.
Old Feb 13, 2011 | 07:44 PM
mac1911's Avatar
mac1911
I keep both of mine on a tender all year round. Seems to greatly extend battery life.
Old Feb 13, 2011 | 07:48 PM
rstekeur's Avatar
rstekeur
if i dont ride mine for around a week the battery is too low to start. battery is about 1.5 years old.
Old Feb 13, 2011 | 07:54 PM
smithbrl's Avatar
smithbrl
I'm guessing that you have a battery drain issue. At a rate of 110 milliamps, about .1 amps, the battery will discharge 1 amp in 10 hrs.(.1 Ah). Therefore, in 300 hrs. the battery will have discharged 30 Ah, or be discharged. 300 hrs=12.5 days. This is a rough calculation and because the discharge rate is so small, the battery will last longer than 12.5days but probably not much.
This is based on some quick research and I don't guarantee exact results.
Cecil
