GLIDE PRO feed back anyone?
Old Feb 17, 2011 | 10:25 PM
sam73801's Avatar
sam73801
6th Gear
The GlidePro system fixes the root cause of the problem, rather than adding a brace to control it. I watched him do an alignment a few weeks ago, he really knows what he is doing. Check out the videos on his website.
Old Feb 17, 2011 | 10:42 PM
chateau's Avatar
chateau
Buddy of mine put one on his 08 Ultra and took it off the next day. Didn't like the added vibration in the floor boards.
Old Feb 17, 2011 | 11:47 PM
Moe Taters's Avatar
Moe Taters
The Glide-Pro system truely fixes the problem rather than moving the problem somewhere else.. I am very happy with mine.. I have put about 17,000 miles on this system..
Moe Taters
Old Feb 21, 2011 | 09:25 PM
fabrik8r's Avatar
fabrik8r
Probably sending my Glide-Pro system back. I already had the Sta-Bo, and the new style Glide-Pro system is not an improvement over the simple and much cheaper Sta-Bo, I did notice more vibration with the Glide-Pro. I’m sure that anyone who installed this system as a replacement to the OEM bushings noticed a significant handling improvement but you can achieve better results for a lot less money. The earlier version of Glide-Pro was similar to Sta-Bo but better built. The new Glide-Pro consists of much tighter fitting pivot shaft with some low profile aircraft nuts and complete new bushings, instead of adding support bushings to the OEM swingarm bushings. As with most things I have studied long on the new style Glide-Pro system and it simply cannot accomplish the claims. The dual density bushing theory is sound but the design does not accomplish the concept. The Idea is the harder outer material supports the swing-arm while the softer inner material absorbs engine mount vibrations. In the simplest terms, the engine/trans, swing-arm, and bushings are all bolted together tight as a single unit on the pivot shaft and the softer core Glide-Pro bushings still support the group in the same manner as the harder OEM bushings. It is impossible for this design to effectively manage rear engine mount vibration damping and swing-arm support in one bushing. Harley got it wrong to start with and now Glide-Pro’s New improved system is just as wrong, they took a very fancy step backwards. I actually experience more undesirable motion in the swing-arm now than I did with the OEM bushings and Sta-Bo. The new bushings have the pivot shaft hole in the center as opposed to offset high like the OEMs, this combined with the softer core bushing actually allows the weight of the engine/trans/swing-arm group to “sag”. I have very little clearance now between the transmission and frame cross-member. Not sure if there is actually an issue from the driveline/suspension geometry change but its another consideration. The jury is still out on the front motor mount. It is soft, and allows the motor to rock freely for and aft, just not sure how it works since the metal core sleeve of the bushing is not cast into the urethane material, but floats freely and can be pushed out the top or bottom of the mount. It’s basically a new broken motor mount with the core completely separated from the damping material. The front mount main bolt basically squeezes the metal mount sleeve and there is a ź” gap between the bottom washer and the lower urethane material, its like the mount isn’t even connected to the motor. Anyway, going to reinstall the OEM bushings and Sta-Bo in conjunction with the Glide–Pro front motor mount to see how it works together. I’m not yet saying the front mount doesn’t work, still need to evaluate. I imagine I’ll have a bunch of Glide-Pro believers telling me how wrong I am, but I know what I know. Save your money, use Sta-Bo instead.
Old Feb 21, 2011 | 10:14 PM
Jerzmatic's Avatar
Jerzmatic
I just ordered the Alloy Art Touring TXR-1 Stabilizer does anyone have any experience with these? It should be here Wednesday and i'm hoping my high speed dancing goes away.
Old Feb 22, 2011 | 07:28 AM
ncbeast's Avatar
ncbeast
I just want to get the front motor mount to cut down on some of the vibrations through the handlebars and seat.
Old Feb 22, 2011 | 04:38 PM
cdesero's Avatar
cdesero
Just installed the front mount today and the rear sometime soon. We have about a foot of snow on the ground i have lots of time .
Old Feb 22, 2011 | 04:45 PM
cuda67bnl's Avatar
cuda67bnl
I tried the glide-pro stuff last year. Took it off and sent it back a few days later. The vibrations were rediculous and made riding 30 or 40 miles unbearable. I couldn't imagine trying to ride several hundred miles with it.
Old Feb 22, 2011 | 07:49 PM
Snowfly's Avatar
Snowfly
My original front motor mount on my 05 ultra was starting to tear and separate so I replaced it with the glide pro late last season. I don't have a lot of miles on it but I'm not so sure I like it. I have added vibration in my floorboards, kind of like a buzz that I didn't have with the original Harley 79-B mount. The glide pro was an improvement over the "broken" mount but anything would be an improvement over something broken. I think I'm going to try the Harley replacement for the 79-B in the spring.
Old Feb 22, 2011 | 08:19 PM
02GhostRiderVA's Avatar
02GhostRiderVA
Great thread! I was actually discussing the purchase of the Glide Pro rear system with a buddy earlier today. Their motor mount was installed over 5K miles ago and I am completely satisfied with its performance to date. Anyone wanting to rid themselves of a Glide Pro rear system (2002 RKC), feel free to contact me.
