FLHRCI and K&N / mapping?
Old Feb 16, 2011 | 08:10 AM
SHAKEME's Avatar
SHAKEME
Default FLHRCI and K&N / mapping?
Hi,
on my FLHRCI `00 with Kess-Tech-Pipes i have the stock air filter (# 29462-99 ). Now i want to replace it with the K&N (#HD-8899).
Reading through the Forum, one says "No need to remap", next one "You have to".
Well, do I need a new setup?
Greez from Germany
ShakeMe
Old Feb 16, 2011 | 08:24 AM
Mike T's Avatar
Mike T
Originally Posted by SHAKEME
Hi,
Greez from Germany
ShakeMe
If you do one or the other there's no need to remap. If you do both it's gonna run lean on you thus the remap.
Old Feb 16, 2011 | 12:29 PM
mjb765's Avatar
mjb765
The bike starts out lean from the factory, so it will be worse after the mods. Definitely requires a tuner. You will hear people that say no, but the bike will run better after the tuner is installed.
Old Feb 17, 2011 | 03:59 PM
James_Johnston's Avatar
James_Johnston
Former Sponsor
Mike T and mjb765 are both correct.
If you do one or the other, unless you were really lean to start, you should not need to remap; but... there are some cases where the bike was too lean to start. From my personal experience if you do both, even though it is just a drop in filter, remap. Like mjb765 said, the programming tends to be lean to start, so adding both mods, especially if you go up to a stage I, you will end up really lean without a remap. Plus the mods work that much better with a remap.
Old Feb 18, 2011 | 02:22 AM
SHAKEME's Avatar
SHAKEME
Thank for your answers.
I think i'll go then for a PC III.
mn-wild-1
Exhaust System Topics
Apr 30, 2013 03:54 AM
sioux565
Dec 12, 2011 10:33 AM
Weatheredge
May 30, 2011 06:52 PM
jupiter2
Feb 21, 2011 08:57 PM
shore
Feb 4, 2011 07:36 PM
