Gauge Dash Lights?
Old Oct 8, 2006 | 05:34 PM
VROCK SE's Avatar
VROCK SE
Default Gauge Dash Lights?
oK Gurus,
Is there any way to change the color of the Gauge lights?
Old Oct 8, 2006 | 05:52 PM
Ram's Avatar
Ram
Default RE: Gauge Dash Lights?
I know of two ways to change, that is if you can get to the bulbs or the bulb holders and take them out from behind the gauges!
1. To put little condom looking things (yes this is a real deal thing) on the bulb that allows the light from the bulb to be changed to what ever you want / or change to a totally different color bulb colored glass.
2. Change the bulbs out with LED's. They have a ton of different colors and are usually brighter than stock bulbs. Or you can even order super bright LED's with or with out color. May cost more but will virtually never burn out.
Note: that different style (focus point vice broadcast of light lum's) LED's are used for blinker / hi-beams than for general gauge lumination.
Old Oct 8, 2006 | 06:10 PM
gabhart's Avatar
gabhart
The speedometer and tachometer are sealed units. You would have to do major surgery to change those.
Old Oct 8, 2006 | 08:35 PM
Jerry L's Avatar
Jerry L
I haven't done business with these guys, but found them on the web for the speedo and tach.
http://www.bluegauges.com/motorcycle/harley.htm
Jerry
Old Oct 8, 2006 | 09:17 PM
Ram's Avatar
Ram
ORIGINAL: Jerry L
Jerry
Thanks Jerry now I know of Three ways!
Old Oct 8, 2006 | 10:05 PM
Jerry L's Avatar
Jerry L
You're welcome, but here's another way too. Harley did make some colored bulbs in 2001. Check out that accessory catalog or I can post the numbers for the colors you want. I checked the Chicago HD parts site and they still look like good numbers. I've been checking myself lately, like to go with blue, haven't decided yet.
Jerry
Old Oct 9, 2006 | 09:43 AM
bradteed's Avatar
bradteed
I changed my bulbs with some cheap 194 bulbs I found at the discount autoparts store. The Speedo/Tach are sealed, so I changed the four guages surrounding the tach/speedo to red to match the color of the radio on my 2001 Ultra.
Old Oct 9, 2006 | 09:59 AM
dgriffith's Avatar
dgriffith
Jerry I,m also interested in changing my guage lights colors, I have an optic trouble with red lights on guages. I need all if mine in green if at all possible if it means buying new guages tach. spedo. any part numbers for those bulbs? thanks Dan
Old Oct 9, 2006 | 08:39 PM
VROCK SE's Avatar
VROCK SE
I want all of mine RED
Old Oct 9, 2006 | 08:41 PM
2006ultra's Avatar
2006ultra
I'm willing to do major surgery, how do I get the speedo and tach apart?
