Security System Help
Old Feb 20, 2011 | 03:45 PM
Rob0331's Avatar
Rob0331
Default Security System Help
The key light does not blink, the turn signlas do not work and the bike will not start. Everything powers up, radio, lights etc but the bike won't start.
I checked the fuses but didn't see any that are blown. Not sure how to check the...not sure of the technical term, but the square three and four prong fuses.
It's a 2010 Ultra Classic.
Anyone have any ideas?
Thanks!
Old Feb 20, 2011 | 03:55 PM
jjnoble's Avatar
jjnoble
sure sounds like fuse. did you swap out the ignition fuse with one that works for sure, like the lights. Sometimes it is very hard to tell if they are blown, I've had them not blown and still would not pass current, could be bad even though it looks good.
Old Feb 20, 2011 | 04:11 PM
Rob0331's Avatar
Rob0331
Thanks for the reply. I just swapped out most of the 15a fuses with one that I know works. No luck.
One additional symptom is all of the gage lights work except for the speedometer and tachometer.
Old Feb 20, 2011 | 04:13 PM
kykurnal's Avatar
kykurnal
Bad / dead battery?
Old Feb 20, 2011 | 04:18 PM
Postal Trucker's Avatar
Postal Trucker
Change the battery in the FOB. They go out quick on the new ones. I've had the same problem and the new battery fixed it.
Old Feb 20, 2011 | 04:20 PM
Rob0331's Avatar
Rob0331
Originally Posted by kykurnal
Bad / dead battery?
Nope. Tested it with a multimeter and it is fine. Less than a year old and always has a battery maintainer on it (HD). Thanks!
Old Feb 20, 2011 | 04:28 PM
Rob0331's Avatar
Rob0331
Miltimeter says the battery is good, 2.95v+. Thanks for the suggestion!
Old Feb 20, 2011 | 07:29 PM
Rob0331's Avatar
Rob0331
Looks like I will be visiting the dealership tomorrow. Many thanks to all that replied.
Old Feb 20, 2011 | 08:29 PM
FLPostman's Avatar
FLPostman
Default Security question
Presume you've checked the obvious- run/stop switch on run- bike in neutral..Don't ask me how I know..
Old Feb 20, 2011 | 08:48 PM
cmc seabee's Avatar
cmc seabee
What they said
