Hd drive belt adjustment stupid
Old Feb 22, 2011 | 06:42 PM
Tanker2's Avatar
Tanker2
Default thanks guys
Like I said everyone has a different method. My point was way doesn't Hd come up with a little easier medthod. The book also says it's not correct to use the hand method. Says you need to use the gage. But to each his own. Thanks for the replies.
Old Feb 22, 2011 | 07:14 PM
1931jamesw's Avatar
1931jamesw
Here's my comment: That gauge is a piece of ****!
Old Feb 22, 2011 | 07:59 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
I watched the mechanic at the dealership adjust mine during the 1000 mile service and he removed the muffler on the right side(both bags were already off) and he loosened up the axle nut and tensioned it entirely by feel. He did not use any tool to measure tension.
For what it is worth I was a Gates Industrial Distributor for 17 years. Gates Rubber developed this belt for Harley and I got to meet two of the key players involved in this project several years back. This same belt is used today in industrial applications and it's called a Poly Chain Belt. It is on it's third generation and works great. The only word of caution I can give you is that it is better to error on the side of too tight than too loose. If this belt is too loose to a point that the teeth do not properly mesh with the sprocket it will actually cause/allow the belt to climb the sprocket and the belt will snap clean across instantly like you had cut it with a knife from side to side. This was the biggest problem we encountered from new users of the Poly Chain product.
If you have an extra $800.00 laying around you can buy a Gates "Sonic Tension Meter" and you simply hold it up close to the belt and flick the belt with your finger and it will tell you if it is tensioned correctly according to the two sprocket diameters, the center distance and pitch of the belt which you program in.
Don't make it too difficult because it really isn't.
Old Jan 15, 2012 | 04:58 PM
DallasRider's Avatar
DallasRider
I don't think it is that exact either. I felt mine was loose compared to the HD specs. I went to my local dealership and felt belts on new RKCs. One was tight and another was not as tight as mine. Both had about 5 miles on them.
Old Jan 15, 2012 | 05:11 PM
soos's Avatar
soos
Just twist the belt between your thumb and forefinger to about 45*.
Attached Thumbnails Hd drive belt adjustment stupid-belt-twist-1.jpg   Hd drive belt adjustment stupid-belt-twist-2.jpg
Old Jan 15, 2012 | 05:13 PM
dstrat1's Avatar
dstrat1
they build these things like a john deere tractor and then want to maintain them like a space shuttle..amazing
Old Jan 15, 2012 | 05:36 PM
SpiderPig's Avatar
SpiderPig
Originally Posted by badjustbad
A simple check I've learned is to give the belt a twist. It should twist to 45 degrees with a moderate pressure. This should indicate your belt tension is within tolerances.
Old Jan 16, 2012 | 08:37 AM
grbrown's Avatar
grbrown
I've never used another person when checking belt tension and I have been doing that for over twenty years now. Don't get wound up about it FFS, just check it while on the jiffy and make sure you don't leave it tight. The tension device is a great tool for those of us who don't do this check for a living. It does help when using it if you are cross-eyed, but that isn't essential!
Old Jan 16, 2012 | 08:47 AM
TUCCI's Avatar
TUCCI
How does lowering the rear play into belt tension.....oh lets say 1-2", I would think it tightens it or is it the opposite?
Old Jan 16, 2012 | 08:50 AM
TUCCI's Avatar
TUCCI
Tells us the rest....twist between forefinger to 45* then .....what?
