New for 2011 combination speedo/tach
Old May 17, 2011 | 09:24 PM
  #51
ehans's Avatar
ehans
Originally Posted by 105th HD Heritage
The only thing that sucks is that after 31 miles it's married to the bike and and vin number.
That does suck. No transferring it to a different bike later I guess.
Old May 17, 2011 | 10:44 PM
  #52
tduff's Avatar
tduff
Originally Posted by Port Dawg
Mark- Any luck on the pictures?
Also wondering if you guys who have done this wouldn't mind scanning the install sheet and posting it?
Here is the instructions that came with the speedo...
File Type: zip
Old May 18, 2011 | 07:53 AM
  #53
ehans's Avatar
ehans
Thanks Tduff!
Old May 18, 2011 | 08:43 AM
  #54
Port Dawg's Avatar
Port Dawg
Thanks and great choice in bike and color
Old May 18, 2011 | 09:50 AM
  #55
tduff's Avatar
tduff
Thanks Port Dawg, I like yours as well. The install was pretty straight forward and went like this...Checked odometer reading and then removed left saddlebag, left side cover, and seat. Connected the data transfer cable that was supplied with the new speedo to the new speedo and to the data link connector found behind the left side cover. Set console switch to IGN position and RUN swith on (data transfered in about 10 seconds), turned IGN OFF and disconnected new speedo from data link. Pulled MAIN fuse and covered gas tank with soft cloth. Removed dash/console and disconnected connector from old speedo. Removed retainer and pulled speedo out and removed gasket from old speedo. Installed gasket on new speedo and set it in the console. Aligned and replaced retainer on back of new speedo. Pushed connector onto new speedo and then re-attached the console to the tank. Replaced MAIN fuse and set console switch to IGN and RUN to on to power things up. Checked odometer for correct reading and turned switches off. Reinstalled side cover, seat and saddlebag and then you're done except for configuring the new speedo to the colors you want and info you want displayed.
It was pretty easy and only took about 25 minutes.
Troy
Old May 18, 2011 | 10:25 AM
  #56
BigAlsRK's Avatar
BigAlsRK
Default Cop RK
Will this work on a Cop RK? Would like to get rid of the bar mounted tach.
Old May 18, 2011 | 12:32 PM
  #57
shezaharley's Avatar
shezaharley
Originally Posted by knuckleheadz
Yeah, unfortunately it won't fit earlier models but I think they're working on that...
I really hope they do. I have damaged hearing and ride with earplugs, so sometimes it's difficult for me to tell if I'm in the right gear. I could really use the tach and the gear indicator for my 2007 RKC trike.
Liz
Old May 18, 2011 | 02:22 PM
  #58
tooloudman's Avatar
tooloudman
[quote=Port Dawg;8333138]Mark- Any luck on the pictures?
Here you go, not best quality picture but gives you the idea!
Great upgrade
Attached Thumbnails New for 2011 combination speedo/tach-speedo-tach-combo.jpg
Old May 18, 2011 | 04:28 PM
  #59
Port Dawg's Avatar
Port Dawg
Thanks for the pic looks good and thanks for the step by step tduff! Seems pretty straight forward on what to do!
Old Jun 6, 2011 | 10:00 PM
  #60
MadIrish's Avatar
MadIrish
Install couldn't have been easier. Only hard part is trying to figure out which of 600 colors you want to make each section or needle....
Hardest part was getting the connector disengaged from the original speedo, lol.
