Brake Lights / Anyone one add extra's
Old Feb 23, 2011 | 02:55 AM
Trailfndr's Avatar
Trailfndr
Wife had me install a brake/turn/ruinning light setup built into a liscense plate frame. Strips on all four sides, top and botom Red, sides Amber. I can see her brakes come on nearly a mile in front of me. darn things are bright as all get out.
License Plate Frame
Old Feb 23, 2011 | 06:19 AM
dansflhti's Avatar
dansflhti
On my 09 EG Classic I installed the HD fender tip run/brake light,HD LED tail light,and late last fall I installed the HD LED run/brake/turn signals.She really lights up when you put on the brakes.
Old Feb 23, 2011 | 08:02 AM
grbrown's Avatar
grbrown
I have a lid-mounted Harley light on my tourpak and a pair of LED side/brake LED custom lights, one under each corner of it, plus LED rear/brake, so four rear/brake lights in all.
Old Feb 23, 2011 | 09:24 AM
jjnoble's Avatar
jjnoble
Default (DXLED09B) AXIXTECH Xtreme Series Dual Color 9 Diode
Try these. If they don't work, you should probably stay off the road.
(DXLED09B) AXIXTECH Xtreme Series Dual Color 9 Diode Surface Mount Modules - NEW MODEL NOW IN STOCK! NEW 5 WIRE VERSION DESIGNATES SPECIFIC COLOR TO SPECIFIC WIRE/LEAD. NO MORE GUESSING IF THE MOMENTARY SWITCH WAS PUSHED CORRECTLY! Dual color LED technology! Diode actually change color. Axixtech Extreme Optix provide superior off axis light dispersement. Use one color, or both depending on the situation. One light can serve two functions. Available in Amber/Blue, Amber/Red, Red/Blue (choose at purchase)
12-24vdc - 5.8W x 2.2D x 1.2H
http://www.koolglo.com/strobes/html/surface_mounts.html
Old Feb 23, 2011 | 09:28 AM
vet767's Avatar
vet767
Originally Posted by SteveO
Harley has a plug and play kit that makes the turn signals come on with your brake lights and they are real bright, there is also one that will flash the brake light a couple of times then stay on when you apply the brakes.
+1 on That have them on my dyna and the rkc lots of extra light both day and nite
Old Feb 23, 2011 | 09:44 AM
Harleypingman's Avatar
Harleypingman
BAL-1 tail light; $199 list and worth every penny.
Carl
Old Feb 23, 2011 | 09:45 AM
OldPhat's Avatar
OldPhat
My son and I both add the H-D plug in kit that use the rear turn signals as brake lights and running lights. Any help to make us more visible, and wake up the cage people.
Old Feb 23, 2011 | 11:12 AM
mphamrick's Avatar
mphamrick
I have a tail light that is made from bright *** lights that strobs, I added the LED turn signals on the front and back. The turn signals on the back act as another set of brake lights.
Old Feb 23, 2011 | 11:53 AM
2004Sierra's Avatar
2004Sierra
HD Run/Turn/Brake module.
BAL 1 Bright *** Light.
A very visible rear end. LOL
Seriously, I get comments all the time from guys behind me on a ride.
They all comment on how bright the lights are, especially the Bright *** taillamp.
PriestFan
Aug 2, 2007 07:09 AM
wldbill
Apr 3, 2007 08:02 PM
DGlide04
Oct 5, 2006 10:58 PM
rideon
Aug 24, 2006 08:52 AM
territory145
Aug 7, 2006 06:24 PM
