If you go with a new seat, keep in mind the 11 RK comes stock with a lower seat then the 9 and 10 had. I'm 5' 9" and I would like to go down about 1" but I'm not sure what seat is lower then the 11 stock seat.
I have a new Road King and the new frame ('09 and newer) is indeed quite a bit taller than my last Road King (2004). My inseam is only 24".
I put a 1" kit in the front, Street Glide shocks on the rear (1" shorter), and a "block kit" on those rear shocks for another 1" on the rear.
I usually do a Badlander seat on my Kings, but opted for the Sidekick seat this time.
TW. I love your bike, I am stealing alot of idea's of your build. The new steel toe boots I bought seem to a 1/2 inch to my height.
Yep, the boots would help me too, but I went from boots to sneakers about 25 years ago due to a badly broken leg/ankle suffered at the hands of a cager and still can't get comfortable in boots.
I lowered my '09 RK 1 inch in the front with a Progressive spring package...it VASTLY improved the front end handling and braking conditions over the stock suspension..virtually eliminated any brake dive..... I lowered the rear 1 1/2 inches by having Phoenix Customs/Bittchin Baggers rebuild my stock harley shocks... they did a remarkable job lowering them without giving up all the travel and they ride every bit as well as the full height shocks did... cheap money too... excellent people to work with!
I had my factory seat reworked by Allen at Mean City Cycles.. he got it down an inch, moved me back a bit and made it way more comfortable.... I did have Danny Gray make me a seat this Winter that is even lower and hugs the bike much better.... all in all.. these things made my bike lower without sacrificing any ride or handling characteristics except lower lean angles.... I do drag the jiffy stand on left turns more often now......
I just purchased the lowering kit front and back from the MoCo and also I went with the Danny Gray SpeedCradle Solo Seat for FLHR
So I guess I will be sitting pretty low. As far as twisties is concerned I ride very conservatively and defensively. I do not lean the bike as much as other people. So I think I should be straight.
I am sure everyone knows you can raise your foot boards slightly to avoid scraping and potential highsiding. A friend trashed his bike when he highsided the day after lowering and not thinking about reduced clearance. Also don't over tighten the pivot bolts holding the boards to the mounts. Make sure the boards will tilt if they contact the pavement. Sparks can be fun if done with care and thought
I'm 5'6" with a 28" inseam. I have a 09 Road King Classic with the following mods:
12" Progressive 440 shocks lower the rear 1"
Progressive lowering springs to lower the front 1"
Corbin Close Solo seat which puts me down another 1" and forward 1-1/2"
Wild One's 517 bars which bring the bars up and back
Harley Jiffy Stand extension
Chippewa loging boots with 2" heel
Bike fits me perfectly now and I can comfortably flat foot it. There is a trade off with the lowering shocks which cause the ride to be stiffer and rougher, but I had no choice. Other recommendations above would likely get you a similar result to mine at a lower cost.
Another option is lowering blocks, I just installed LA Choppers lower kit on the rear shocks. They will give you an inch. SG or RG shocks friom E bay, and blocks will give you 2".
I am 5'6" / 29" inseams and 190 Lbs. I needed to do the same thing to my bike on a 09 Roadglide. The first thing that I had to lowered was the rear stock shocks 1 inch with a lowering bracket from ebay, then the front drop-in shocks from Pregressive Suspension lowered 1 inch and now I have the Mustang solo seat which is also lower then the stock. However, I am considering the Progressive 940s for the rear.
