oil temp gauge
Old Oct 12, 2006 | 08:39 AM
joe's Avatar
joe
Default oil temp gauge
i recently had an oil temp gauge installed, the harley one that has to be installed by a shop cuz it's a mission and sometimes at 60 mph it goes to 230 degrees but normally is at 200 and once in a while if it is cold will not reg past 160 or around there.on the highway or off. is it normal?i have nothing to compare it to.
Old Oct 12, 2006 | 09:04 AM
sleepneagle's Avatar
sleepneagle
Default RE: oil temp gauge
Yup, the ambient air temp cools the cylinders and oil tank. on cool days, the temp gauge may not even get off the low reading. You ought to see what happens to the temp on a rainy day.
Old Oct 12, 2006 | 09:51 AM
Abnmarine's Avatar
Abnmarine
Mine varies between 200-220 degrees dependant upon the ambient temp. I run Amsoil too so that should help some. Sleepeagle is right about the temp in the rain.
Old Oct 12, 2006 | 02:43 PM
Sportshot's Avatar
Sportshot
Been using an oil temp gauge for years and wait until you ride in 100+ temps and see what the gauge does. The reason I started to use synthetic oil was seeing the temp at about 280 after cruising on the freeway at about 85 mph. One thing I can tell you is what really heats the oil up is higher rpm's and stop and go traffic. You would think that traveling at 80 mph would put enough air across the engine to cool it off, NOT! I find that 3000 rpm's and more on my00 Standard really start to heat things up when the temperatures are above 90 degrees. If think my servie manual said normal operating temp of a twin cam was 215 degrees F.
Old Oct 12, 2006 | 03:04 PM
sleepneagle
That's when you add a cooler.
Old Oct 12, 2006 | 03:08 PM
jackj's Avatar
jackj
yes normal operating temp is 230, that is why "230" is @ the 12 oclock position on the gauge
Old Oct 14, 2006 | 08:59 AM
joe's Avatar
joe
thanks guys will keep it in mind.
GymChamp
Nov 16, 2022 06:18 PM
FLH05
Apr 4, 2010 11:26 AM
mainshaft
Oil Archive (no new posts)
Mar 26, 2009 06:56 PM
thumper05
Apr 24, 2008 10:47 AM
2006ultra
Jun 16, 2006 01:03 PM
