Wheel Bearings Replacement
Old Mar 11, 2011 | 03:16 PM
Terrabella's Avatar
Terrabella
Default Wheel Bearings Replacement
Does anyone know the correct front and rear wheel bearings to a 2009 Ultra Classic with ABS brakes? I called Timken Bearings but got little help other than to try Auto Zone. I am showing a little bit of grease on my front wheel so I am a little concerned so I am going to change the bearings now. I have heard Timken is the best bearing you can buy.
Any input as to part number and \or suggestions for this would be appreciated.
Old Mar 11, 2011 | 04:00 PM
tj316's Avatar
tj316
9252/abs , 9276/non-abs
Old Mar 11, 2011 | 04:14 PM
atrain68's Avatar
atrain68
I bought mine on Dennis Kirk. You can find a good set of All-***** bearings there. The Drag Specialties stuff might be All-*****, but I'm not 100% on that. Good call on the bearing replacement. For some reason the ones the dealers sell don't last long.
Old Mar 12, 2011 | 01:10 PM
canuck pride's Avatar
canuck pride
Yes very good move. Mine lasted 15,000 km on the front. yikes
Old Mar 16, 2011 | 10:39 AM
Terrabella's Avatar
Terrabella
Thanks tj316. As I am finding out, Harley is the only ones who make bearings for the ABS model. To my knowledge, no one else makes them for this application.
Old Mar 12, 2012 | 11:31 PM
r_ham's Avatar
r_ham
Default chinese bearings
Another good reason to avoid the abs. My front bearings lasted less than 5000 kilometers.HD stock abs and apparently made in China, China does not make good bearings! Timken bearings are decent.
Old Mar 12, 2012 | 11:39 PM
JayStronghawk's Avatar
JayStronghawk
Had my Bearings on my 09 Ultra 50K+ now .. Replacing when change the tires soon .. ABS is correct with 9252 .. The standard bearing is now numbered 9276A whether that means a New Vendor or Modification not sure ...
Old Mar 13, 2012 | 06:46 AM
dawg's Avatar
dawg
It means that the 9276 on the 2009's were/are prone to failing miserably!
Old Mar 13, 2012 | 09:20 AM
grbrown's Avatar
grbrown
If it is any consolation when I had my original Buell Firebolt tyres replaced a few months ago both bearings were past it. Fortunately they are a standard size and readily available from alternative brands......
Rumblin
Jul 6, 2018 11:49 AM
JakeUSAF
2014-2024 Touring Models
31
Dec 10, 2017 08:10 AM
itscaptaincody
Southwest
Aug 19, 2017 12:09 PM
Dguy
Oct 28, 2014 06:47 AM
itsmf
Dec 26, 2011 10:17 AM
