Cold Fingers
Old Mar 11, 2011 | 08:35 PM
strtarrow's Avatar
strtarrow
Another Gerbing's fan. Like American Express, don't leave home without it.... Then again there are companies like Brukus (my favorite and a HDF sponsor) that sells some sort wind blocker. Check their link and you will find a few things you MUST have. BTW, they do not pay me for promoting their products. Just think they have great products!!!
Old Mar 11, 2011 | 08:47 PM
willcatchum's Avatar
willcatchum
I have the same problem. It must be the way the wind is forced around the windshield. I had a Suzuki Boulevard with no shield and never had a prob. I know that sounds odd but my hands get colder with my RK. $129 is a big investment to me. If it gets below 32 I won't ride much due to the fear of ice anyway. Lots of creek evaproation where I live. The gloves may keep the ice off my fingers but it doesnt work for the road.
Old Mar 11, 2011 | 08:55 PM
2WheelThrill's Avatar
2WheelThrill
I'm trying to visualize how the gloves would connect to the battery...I only want gloves, not a connecting jacket, pants, etc.
Old Mar 11, 2011 | 10:04 PM
Tek74's Avatar
Tek74
Those with electric gloves are usually always dead set on them and will recomend nothing else but them. I'm personally in the same boat as you, and don't want to be connected to the bike. It just seems a little to Cyborgish.....if that's a word.
I personally wear leather gloves with Thinsulate lining. They keep my hands fairly warm down into the mid-to-high 30's, but after 30 minutes I also start to notice my finger tips getting uncomfortably cold. Hence my decision to add heated handgrips to the bike. Since HD heated grips have way too many bad reviews, I went with the Heat Demons. They are significantly cheape,r and I was unable to find a single bad review on them.
Many fans of electric gloves say they've tried heated grip, and switched to electric gloves because they fail to keep the tops of your hands warm. Since you appear to have only have a problem with your finger tips (like myself), I'm thinking that heated grips may be the way to go for you. Your finger tips will touch the warm grips and stay warm.
PS....you highjacked my Avatar, so I used it as an excuse to install a new one.
Old Mar 12, 2011 | 01:57 AM
Mr Cujo's Avatar
Mr Cujo
Ski, snowboard, or snowmobile gloves.
Work like a champ, no cords.
Old Mar 12, 2011 | 05:18 AM
Jrsess's Avatar
Jrsess
You can also get electric gloves that have rechargeable battery packs. I think they last any where from 2-3 hours depending on temp setting.
Old Mar 12, 2011 | 06:36 AM
viperr817's Avatar
viperr817
Heat Demons! Made in u.s.a.!!!
Old Mar 12, 2011 | 06:38 AM
Notgrownup's Avatar
Notgrownup
If you don't want to get electric (boogy woogy woogy) get snowmobile mittens.
Old Mar 12, 2011 | 08:02 AM
dougbk's Avatar
dougbk
There is a pigtail that connects to the bike's 12v battery (like a battery tender) and the other end of the wire has a coaxial connector which comes out somewhere from under the seat. I find the front of the seat is more convenient. That coaxial connector would connect into a rocker switch or variable controller depending on preference. That would connect into a y-wire what has coaxial connectors that you would run under your coat and down your sleeves to the connect to the gloves. The coaxial connectors are pretty much standard so the components form different manufactures like gerbings and warm n safe will work together. The harley branded heat gear is manufactured by gerbings.
Hoped that help you get a picture in your minds eye. Below are some links that may help.
http://cozywinters.com/heated-clothing/
http://gerbing.com/
http://www.heatedclothingoutlet.com/index.shtml
http://www.warmnsafe.com/
Old Mar 12, 2011 | 08:09 AM
dougbk's Avatar
dougbk
I use the classic lined glove from this company and my fingers are normally good until the upper 30's. With that being said everybody is different when it comes to what will keep them warm, so what works for me may not for you.
http://www.huggergloves.com/
