Floorboard Vibration
Old Mar 13, 2011 | 08:09 PM
jcanrun's Avatar
jcanrun
Default Floorboard Vibration
I recently got my bike back from the shop where the engine was rebuilt due to a bad connecting rod/sissoring flywheel. I had them upgrade to a S&S flywheel which was welded/balanced, and also the case was machined and the timken bearings were installed.
I've noticed now that there is a definite vibration coming thru both floorboards. Kind of annoying and I don't remember this vibration before. I checked the floorboard fastners and all are nice and tight. I noticed in the service manual, that when you take apart the floorboards, the manual states to install "new" floorboard inserts, the rubber mat part of the floorboard. I don't think this was done but I don't think they fully took apart the floorboards, maybe just took the whole floorboard assembly off. The vibrations are pretty equal on the right and left side, leading me to believe that the engine just puts out more vibrations. I'm gonna check the engine mounts as well.
Any ideas on this vibration?
Old Mar 13, 2011 | 08:22 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
could be as simple as a heat sheild clamp touching something or as bad as an unbalanced cranck.u wouldnt believe the amount of buzz a heatsheild clamp touching the tranny cover can make.hard part was finding it looked like plenty of clearence when the bike was off but when running it touched and buzzed.
Flufebunekilr
Oct 8, 2017 08:39 PM
FlDog
Aug 15, 2015 01:55 PM
audettd
Jul 22, 2011 06:58 AM
TexasBikeBoy
Jan 23, 2010 05:37 AM
poundcakejake
Aug 31, 2007 04:46 PM
