D&D fatcat
Old Mar 14, 2011 | 07:59 AM
elauee1's Avatar
elauee1
Default D&D fatcat
What kind of results could someone expect from a fltrx stock 96" motor with a thundermax heavy breather and a D&d fat cat with a dynotune. Wondering if a fat cat is overkill for a stock motor
Old Mar 14, 2011 | 09:01 AM
jpalm's Avatar
jpalm
I'm pulling 92TQ/77HP with a D&D and SE stage 1 aircleaner. Tuned by Doc with TTS Mastertune. I'm very happy with the performance. Also, I have the quiet baffle, so you may be able to pull a couple more out of the other baffle. With the proper cam & tuning I would most likely be able to pull 100TQ.
Old Mar 14, 2011 | 09:02 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You will get a very nice boost with a fatcat.
Drew
Old Mar 14, 2011 | 09:08 AM
fripple's Avatar
fripple
I grabbed 109 tq with a 204 cam in a 96" with the fatcat. That sucker was freaking loud too...WAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHH
Old Mar 14, 2011 | 11:54 AM
SPARKY01's Avatar
SPARKY01
96" with sert, 211 cams , heavy breather, fatcat, and tuned. Numbers below
Old Mar 14, 2011 | 12:00 PM
arealinvestor's Avatar
arealinvestor
It's not really the pipe itself that's overkill,it's what baffle you choice that could be overkill.For a stock motor i would go with the standard baffle(the concentric baffle is to restrictive for anything other than a stock motor).If your planning upgrades go with the performance baffle.It will handle up to, & including a 117ci.
Old Mar 14, 2011 | 12:26 PM
Northside's Avatar
Northside
The numbers will show an improvement from most stock or even aftermarket dual exhaust setups. I gained 10 h.p. and a couple of ft. Lbs. of torque over V&H true duals on my 103. The real improvement is in throttle response and low end grunt. Screw the numbers. Grab some throttle and it jumps a lot better than before. Way more fun to ride, and your bike will look way cleaner without all that crossover plumbing and big *** mufflers under both bags.
Born2cure
Mar 29, 2012 09:41 PM
Dick1964
Sep 7, 2010 10:46 AM
Badbagger
Nov 1, 2007 09:02 PM
norfolk88
Exhaust System Topics
Aug 2, 2007 05:10 PM
WS6 Formula
Pacific
Feb 13, 2007 04:23 AM
