[quote=DocHarley;8059242]Yes, it would be OK but the bike will not handle or look as good then if you lower the front end. I lowered mine around 1 1/2 with a 21" wheel and the handling is better then stock IMO.
how did you lower the front 1 1/2"..the lowering springs say 3/4 to 1"....thx
PROGRESSIVE SUSPENSION DROP-IN FRONT FORK LOWERING SYSTEM
Transforms a time-consuming installation process into a quick and simple job
Lowers front end of your bike up to 2" without disassembling the forks
Entire procedure can be accomplished with basic tools
Made in the U.S.A.
TOURING Models 1997--2011 (Except 02-05 Fairing Models)
Use the included PVC spacers and cut to desired length up to a 2" drop.
I had 2 06 street glides both with a 21 up front loved how it rode and handled gona do it on my 11 also . I lowered the front 2 inches on both but it rides a little harder .I have a kit its a progressive 10-1561 ( check fitment) $50 pm me if you are interested
I have a 2006 electra glide standard and want a 21 inch wheel as well. Can i leave the stock 16 in the rear or does it need to be changed? Having trouble finding the answer
I have the 21/16 set up and it rides the same to me. I did lower front 1",
So I would say the answer is you can leave the 16 on rear.
