HD Audio iPod Interface Install - 2011 RGC
I've unplug the two other plugs no less the 10 times. No Ipod option shows on the face...nothing...wont even charge what ever is connected to it.
I bought the interface from the local HD shop on Tuesday. They had two on the self so I took the one I had back and tried the other...same results. Instructions are dated 2011-09-22.
I'm more than likely gonna have to take it in and have them look at it. If the tech I think did the flash for the intercom did then I'd guess he is at fault...he's mess up stuff on both my bikes doing warranty work and I wont let him touch them now.
Just a note on the parts list above regarding the 69200033 harness. If you have an Ultra or have added the non-Ultra overlay harness (used when adding HD's XM, CB, rear speakers/pods to the King Tour Pak), you won't need that harness since your bike already has 35 wire connector plugged into the HK. Ditto those who have added the HD intercom kit, p/n 77107-08 since that kit also includes 35 wire connector.
FLHT/C,FLHX,FLTR/X and FLHXXX models WITHOUT Non-Ultra Overlay Harness (Part No.70169-06) installed will require separate purchase of a Connector Kit (Part No. 69200033)
Once I figured it out I thought a few more pictures would be helpful.
The first thing that I was unclear on was how to unlock the connector. As has been stated, the wedgeblock should NOT be removed, but it IS necessary to unlock it. The pdf instruction sheet from TE (http://www.te.com/catalog/bin/TE.Con...267,63261&N=19) doesn't really look like the connector here so the instructions leave something to be desired with respect to (WRT) unlocking the wedgeblock.
The wedgeblock needs to be lifted so that the red center part is no longer flush with the black edge. Putting a small screwdriver between the gasket and the edge of the red block and levering against the connector housing is how that is done. You don't poke the screwdriver into the housing beneath the gasket as the pdf seems (to me, anyway) to imply.
Once the wedgeblock is unlocked and the seal plugs have been pulled out (just grab 'em with needle-nose pliers and pull 'em out), insert the new sockets in the appropriate socket holes until you can see them at the same level as the ones already there. Press the wedgeblock back into the locked position and visually inspect to make sure the new sockets are at the same level as all the others and you should be good to go.
The job took far longer for me than it should have because these things weren't clear to me. I now believe that I could do the entire mod in a couple of hours or so from prepping the bike to returning to service.
I couldn't have done it without the great instructions initially provided, but since others seemed to continue to have issues with the connector I felt this might help. As this is my first post to the list I hope the pictures are submitted correctly.
Also, just echoing other posts. The 35pin has to be unlocked in order to get the pins deep enough and aligned with the rest of the pins. However, this was easier than I expected (and I can do it, anyone can do it).
