PCV problem
Old Mar 17, 2011 | 09:15 PM
Hrlyrider's Avatar
Hrlyrider
Default PCV problem
Bought a PCV from fuel moto and have had it on the bike for a little over a year now. Well just bought new true dual head pipe for my Vance and Hines slip on's. I got a new download from fuel moto but problem is when I hook up to the PCV it doesn't seem to do anything. It's like it is not even hooked up. I can't put the new download in. Any suggestions? Yes I did have the usb cable pluged all the way in, I tried to push it in tighter but nothing.
Old Mar 17, 2011 | 09:24 PM
montanacharlie's Avatar
montanacharlie
Sounds like its time to call Jamie. Did you try a different USB port on your computer? Or maybe a different computer? Might be time to make use of the warranty...
Old Mar 17, 2011 | 09:28 PM
18BKLR's Avatar
18BKLR
Did you turn the ignition on. Has to have power to fire the PCV up. Just a thought
Old Mar 17, 2011 | 09:29 PM
Hrlyrider's Avatar
Hrlyrider
hooked it up to a different bike and it works fine so I think it's the PCV
user 8373900's Avatar
user 8373900
There are known problems with the CD's that come from Dyno Jet. Download the software from Jamie's web site or Dyno Jet's web site..I'll bet it goes then.
Mark
Old Mar 17, 2011 | 09:30 PM
Hrlyrider's Avatar
Hrlyrider
even when it was hooked up with bike running it showed nothing on the screen like it was not hooked up
user 8373900
the PCV is powered through the USB cable, no need for the bike power.
Mark
Old Mar 17, 2011 | 09:31 PM
papifun's Avatar
papifun
does the PCV LED turn on when u are trying to program it or when ure bike IGN is on ?
you can pull it out of the bike and still be able to download the Map, shouldnt be necessary though.. i have re-programed while on the bike even if the IGN is off..
Hrlyrider's Avatar
Hrlyrider
Mark
I could not even get my cd to load so that is where I got my software
Old Mar 17, 2011 | 09:34 PM
18BKLR's Avatar
18BKLR
Mark
Your right. Thought of that as soon as I posted. Just trying to think of the stupid stuff.
