HK Radio Update
Old Mar 20, 2011 | 08:00 AM
Lancemchn's Avatar
Lancemchn
Default HK Radio Update
Any tricks to burning the CD? I did just as the directions said but as soon as I put the CD in after going to "update", it says "Verifying DSL..." and stays that way forever. I have an '07 and the version shown is much lower than what's available. Not sure what the update would do but I like to be at the highest possible. Thoughts???
Old Mar 20, 2011 | 08:36 AM
JRBass's Avatar
JRBass
took me three discs to get it right. I was trying to use windows to burn the disc on my laptop and it just wouldn't work. went to other computer and used Nero to make data disk and worked like a charm. try a burning software and not windows.
Old Mar 20, 2011 | 08:55 AM
Lancemchn's Avatar
Lancemchn
Thanks, I'll give that a shot. I also noticed in my research that a lower "burn speed" may help.
streetglide44's Avatar
streetglide44
Never could get mine to take on my 07 SG. New Sony now, good luck.
Old Mar 20, 2011 | 08:57 AM
JRBass's Avatar
JRBass
Yes the directions also say no more than 8x I did it at 4x. very small files so doesn't take long to burn.
Old Mar 20, 2011 | 09:08 AM
blueduramax's Avatar
blueduramax
I put the update disk in my HK radio and it would not come back out. To the dealer we went and new radio ordered.
Old Mar 20, 2011 | 09:22 AM
JRBass's Avatar
JRBass
the directions for updating says that this could happen and gives a solution to get it out. with that being said I did mine and buddies with same disk and no problems.
Old Mar 20, 2011 | 09:32 AM
Lancemchn's Avatar
Lancemchn
Looks like it's working now, even though I could only get it to burn as low as 10x. Took 3 disks but it's updating now. Thanks guys!
Old Mar 20, 2011 | 09:34 AM
JRBass's Avatar
JRBass
No Problem. 3 seems to be the magic number.
Old Mar 20, 2011 | 09:49 AM
Lancemchn's Avatar
Lancemchn
Worked like a charm! 1st thing I noticed was it fixed an issue I was having with "start up" in XM mode. The screen would always look all garbled up until you changed modes or volume, etc. Now XM shows properly from the time the ignition switch is turned on. I'm a happy camper!
