Progressive monotubes on the way
Old Mar 20, 2011 | 10:44 AM
joflewbyu2's Avatar
joflewbyu2
Default Progressive monotubes on the way
Well ordered the Progressive Mono-tube Kit to complement the 12" 440s on my 2010 FLHTP. I have the 440s set with as little preload as possible and the rear does not sag much at all. I am not sure if it is caused by the Police Air Ride seat absorbing the initial weight. I weigh 175 and the Progressives rears are 440-4061B with spring rate of 90/130. I sure hope the standard Mono-tube Kit 31-2501 matches my set up. I ride solo most of the time and since my front fork seal is leaking, I thought it would be a great time to upgrade. Progressive, you out there with some advice input? Thanks !!
Old Mar 20, 2011 | 12:42 PM
rustybags's Avatar
rustybags
5th Gear
I am really curious to see how they work out. I almost ordered them a few times and ended up ordering Works dual rate spring kit instead. I have always used the progressive spring kit in the past and have never been disappointed so I'm sure the monotube will be pretty awesome
Nitro 54
2014-2024 Touring Models
Jul 2, 2018 10:25 PM
fatmanontwowheels
Sep 9, 2014 04:22 PM
ProspectNY
Jul 6, 2014 11:34 AM
Roni
May 20, 2013 07:48 PM
mudbeast2
Jul 8, 2010 07:59 AM
