Where is the hole?
Old Mar 20, 2011 | 04:03 PM
Roger M's Avatar
Roger M
Default Where is the hole?
Hi guys, just fitting a brake/tail lamp kit to my tour pak and am wondering where the wiring exits the pak, what size hole, rough (or precise if possible) location. My bike is an `07 FLHT with detachable rack, if it makes any difference.
Regards, Roger,
P.S. pics would be nice.
Old Mar 20, 2011 | 04:18 PM
smithbrl's Avatar
smithbrl
There's a wire going through a hole in the front right hand side of the tour pack that runs down under the seat. You'll remove the grommet and get rid of it. Run the new wire through the same hole and install the new grommet. It's a tight fit but no problem.
Cecil
Old Mar 20, 2011 | 04:34 PM
shortride's Avatar
shortride
Mine is in the front left corner of the tour pak.
Old Mar 20, 2011 | 09:53 PM
smithbrl's Avatar
smithbrl
The wire coming in on the left side gets cut and the harness is spliced into that and routed around the back of the tour pack to the lights then comes on around to the right side and goes out with a wire that's already there. This is with an 09 Ultra. Should be the same for all, but I'm not sure.
Cecil
albngore
Jan 15, 2019 08:31 PM
WoodyHD
Sep 16, 2010 03:52 PM
gmurdock
Jan 1, 2010 09:03 AM
Smitty
Aug 18, 2007 05:49 PM
