Changing Primary Oil?
Old Mar 22, 2011 | 10:07 PM
Ronp42's Avatar
Ronp42
Account Retired
Originally Posted by 1931jamesw
Probably clutch **** (normal) on the primary plug. I use teflon tape on the threads and the o ring. I wouldnt use pipe dope but I have smoked a dope pipe.
With all due respect, I would not use Teflon tape on the drain plugs. Tell you why! The Teflon Tape crushes in the threads and turns into little strings when tightened. It's acting as a thread lubricant. When you remove the plug and drain your oil, all the Teflon doesn't come out of the threads. When you reapply Teflon and put the plug back in, some of the teflon strings gets pushed into your engine. You don't want that chit floating around in your engine. A lot of Company's like Honeywell outlawed the use of Teflon Tape because it was being pushed into their instruments and causing big problems.
Old Mar 22, 2011 | 10:17 PM
1931jamesw's Avatar
1931jamesw
There certainly is logic to what you are saying. I used to work for an indy here locally and he got me started doing that. He doesnt have the best reputation but never heard of any problems due to the teflon tape....
Old Mar 22, 2011 | 11:50 PM
NoCoLoco's Avatar
NoCoLoco
As long as the rubber O-ring is in good condition and the drain plug is properly tightened there is no need for Teflon tape.
Old Mar 25, 2011 | 01:13 PM
readyfornew59's Avatar
readyfornew59
Pipe dope......now that's a true jerry rig. Man you got to love the tech at these dealerships. And I'm sure there normal reply is "that's normal".
Old Mar 25, 2011 | 01:23 PM
skdvr's Avatar
skdvr
I agree with what most here are saying. No need for dope or tape. Those little O-Rings are awesome at their jobs or sealing.
Phil
Old Mar 25, 2011 | 03:10 PM
hydrolock43's Avatar
hydrolock43
Default Teflon pipe dope
When i got my bike back from the 1k service i thought i was seeing things. The o-ring was hanging off two of the three plugs,some sort of pipe dope they put on the threads would not let the o-ring seat into the small chamfer in the cases because it filled the chamfer that the o-ring was to fit in. Flipped out on the dealership and they told me the tech that did it had worked on Harleys 25 years. The next day Harley Davidson customer service called me to ask what my complaint was about. I told the women that if i ever had another issue with warranty or something that i could not fix that i would burn it and file an insurance claim. Teflon tape is for tapered pipe threads as is pipe dope,a plug with an o-ring that fits into a chamfer is the seal for that plug. To use tape or pipe dope on that plug is a pure idiot period
Old Mar 25, 2011 | 04:21 PM
gmc's Avatar
gmc
They come fr. the factory with dope on the threads, not saying it's right.
Old Mar 25, 2011 | 04:29 PM
rshwetz's Avatar
rshwetz
Default Pipe dope
using pipe dope, like teflon paste is an excellent product and idead
1.) the dope lubricates the threads which in turn will stop the threads from picking up or galling. The plug is carbon steel and the drain holes are aluminum. If you screw up the threads on the drain it will cost a pritty penny to repair.
2.) the dope does not seal it only lubricates, the threads seal.
For me is a little paste on the threads a new o-ring and miles of smiles.
Old Mar 25, 2011 | 08:19 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
if any teflon gets in the oil and makes its way to the o2 sensors they will be trash.the oil all over the threads is all the lube u need.
Old Mar 25, 2011 | 10:23 PM
2black1s's Avatar
2black1s
I don't use tape or dope on the drain plug threads... But if I did, how in the world could it ever get to the 02 sensors?
