PSI for shocks
Old Mar 26, 2011 | 05:00 AM
Xtremerider112's Avatar
Xtremerider112
Im runnin between 20 and 22 solo and around 30 with the Mrs. You really just have to try it out and see what ya like. There is no "right" number, but you'll know the sweet spot when you find it.
Old Mar 26, 2011 | 06:57 AM
Tx_Rider's Avatar
Tx_Rider
You also have to consider how much weight you have in the bags. If you have a lot of tools you need to consider that as well, not just rider weight.
Old Mar 26, 2011 | 07:06 AM
Texas Fat Boy's Avatar
Texas Fat Boy
The shocks changed in 2009, so advice you get from anybody with a 2009 or newer bike won't do you any good.
When I had my 2008 I ran about 15 lbs riding solo and weighing 220
My 2009 takes 28 lbs
Old Mar 26, 2011 | 07:29 AM
streetglide44's Avatar
streetglide44
I have an 07 and my weight is the same@ 240, 15 lbs works for me.
Old Mar 26, 2011 | 07:46 AM
Bodean46's Avatar
Bodean46
I run 11 lbs in rear on my 01 with the wife and our gear. I weigh 230 and she's 170 and rides fine. I have air on front as well and solo i run 11 front and 9 rear and rides better than my car.
Old Mar 26, 2011 | 07:53 AM
Schoondog's Avatar
Schoondog
My 99 Ultra I was @ 15 psi solo and 25 2up, I am 225 and my bags are usually full of stuff. On the new 09 Ultra the suspension is different with a max psi rating of 50 when 2up.
Old Mar 26, 2011 | 08:42 AM
timbo141's Avatar
timbo141
There are two different shocks,
Standard Rear suspension up to 35lbs
Low Profile suspension up to 50lbs
Old Mar 26, 2011 | 09:23 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
On a cool Sunday morning and a road similar to Hwy 299 (Redding - Eureka CA) this is what I use on my 2010 Standard:
2Opsi solo, 25psi w/wife, 30psi w/wife + cargo
or in load equivalents:
20psi @220lbs, 25psi @350lbs, 30psi @400lbs
In warmer conditions I tend to lower shock pressure (by ~5psi) to reduce loss of adherence.
Old Mar 26, 2011 | 11:31 AM
Pass Rider's Avatar
Pass Rider
I run 25 all the time. I like the feel of the bike in curves better at that pressure. Since most of my riding is in the Rocky Mountains, there are a lot of curves.
Old Mar 26, 2011 | 11:36 AM
steelerdude1's Avatar
steelerdude1
Well. looks like it's pretty subjective. I set it @ 25, and will give it a try. I'm certain that the 4 psi that was in there was not enough. I guess I will play around with it a see whats best. Cant do it today, 'cause winter came back, it's 22 deg . . . . . YUK!
