Lever Replacement
Old Mar 27, 2011 | 09:46 PM
sanlyn's Avatar
sanlyn
Default Lever Replacement
I'm getting ready to swap out my clutch and brake levers with new ones, and the instructions I have tell me I need to take the master cylinder cover off, and what's with the cardboard??? Any suggestions?
Old Mar 27, 2011 | 09:53 PM
inthechateau's Avatar
inthechateau
Gasket.
Old Mar 27, 2011 | 09:58 PM
ImNoPrince's Avatar
ImNoPrince
I think this is common to most Harleys but the cardboard helps so you don't break off the Brakelight switch that's in the lever reciever. They are small and weak and easy to push into the reciever the cardboard stops that from happening.
I didn't take my master cyc cover off but it might ask you to do so to relieve pressure to make the install easier .
Dionicio's Avatar
Dionicio
The cardboard is used to prevent the stop light switch from being broken. Use it, you will be glad You did.
Old Mar 28, 2011 | 02:18 PM
sanlyn's Avatar
sanlyn
Is there a particular SIZE or cardboard? just enough to fit in there? I'm assuming it's just a simple swap out from there.
Old Mar 28, 2011 | 04:34 PM
ImNoPrince's Avatar
ImNoPrince
yea you just want to keep the lever away from the switch and this is the easiest way to do so.I bent mine around that area and bent a paperclip to keep it in place Worked well.
yea it only took a few minutes to do my Swap
Old Mar 28, 2011 | 04:41 PM
SteveO's Avatar
SteveO
Popsicle stick or tongue depressor will work.
If you don't use something heavy enough you will break the plastic brake switch when you pull the lever......and you talk about a pain to rewire and re-solder the new brake part in the break lever area !!!
You will know if you have broken it if your brake lights stay on after you have finished.
Old Mar 28, 2011 | 09:40 PM
tat2fatboy's Avatar
tat2fatboy
ditto on that! i replace my grips and broke that brake light switch,cost me $60 bucks for the part and was a pain in the but to replace. i was very carefull with it when i put it back together.
Tampa Fatboy
Aug 8, 2016 02:45 PM
WP50
EVO
13
Jul 22, 2012 08:04 AM
OneBlackFly
General Topics/Tech Tips
Jan 2, 2009 06:14 PM
costaza
Jan 31, 2008 08:58 AM
