AMP for my Bagger
Old Mar 29, 2011 | 11:23 AM
notrailers's Avatar
notrailers
Default AMP for my Bagger
I am looking for a motorcycle amp that will power 2 speakers and will play and charge my ipod. Does anybody know if such a thing exist? I have found plenty of amps that will play the ipod but not charge it.
Thanks!
Old Mar 29, 2011 | 08:47 PM
Landon's Avatar
Landon
check out http://www.hawg-wired.com/
I have a Hogtunes amp and it is ok, but there are much better available.
Old Mar 29, 2011 | 09:49 PM
Lawnboy's Avatar
Lawnboy
Thanks!
I have been searching for something to charge my ipod as well. What I am going to end up doing is adding a charger in my saddlebag that has 3 cig. lighter plugs and a USB charge port. I will have to run a headphone to rca cable to the amp to get sound and will have to run a standard USB charging cable for the ipod. It sucks to run 2 wires, but thats about the only way to do it.
Something else I found out was if you use a cable like this:
which will supposedly charge and play your ipod to an amp via the RCA cables, but if the ipod is your only audio source and its running directly to the amp, it will have a fixed volume output. The volume output is only changed thru the headphone jack, so basically this cable is only good if your hooking it up thru a AUX IN on a headunit.
I hope that makes sense.
Old Mar 29, 2011 | 09:51 PM
Lawnboy's Avatar
Lawnboy
Also if you have some time, you can check out my audio mod write up and it will give you an idea about what I did for my stereo on my bike.
https://www.hdforums.com/forum/touri...ed-fender.html
Old Mar 29, 2011 | 10:19 PM
notrailers's Avatar
notrailers
Lawnboy:
Yes it makes sense. Thank you!
Bunker
Audio Systems
Dec 10, 2015 07:46 PM
remerson
Audio Systems
Jul 15, 2014 03:39 PM
randy98ss
Feb 8, 2014 07:24 PM
CHILLLS
Jun 11, 2012 11:11 AM
Norie1
Mar 21, 2012 07:33 PM
