What did you do to your bagger today?
Old Jan 23, 2017 | 12:18 PM
  #9931
dirtdreamer50's Avatar
dirtdreamer50
Yep. If I wasn't using ear buds, I was wearing plugs. Never ride without plugs, the wind noise is the problem. TINNITUS doesn't help either. Hearing protection is important, whether on short rides or long. tp
Old Jan 23, 2017 | 01:01 PM
  #9932
big papa AZ's Avatar
big papa AZ
Little more work on my budget RK project. Solo seat, rocket fin slip-ons, serviced front brakes. Previous owner had stripped 12 point caliper bolts. Took me 3 hours, 1 broken easy out, 3 drill bits and a dremel to remove them. 21" wheels or different bar set-up next.
Old Jan 23, 2017 | 02:42 PM
  #9933
twp98's Avatar
twp98
Installed new shock, washed, clay bared and waxed. That was some much needed time in the garage today. Now if the rain would stop I would ride and see how the new shocks feel.
Old Jan 24, 2017 | 04:30 AM
  #9934
1HD1C's Avatar
1HD1C
my kingdom for a bike jack!!!
JNR air ride is done except the shocks since last thursday, Friday i excitedly borrowed cousins pitbull jack only to find that the bottle jack is bad, no amount of priming would make it work...
im in limbo until the replacement jack gets here sometime this week and the worst
party is its supposed to be 50+ next couple days
Old Jan 24, 2017 | 06:18 AM
  #9935
raggmann's Avatar
raggmann
Just do one side at a time. I did mine and another one that way. No need for a jack. I swap the right shock first then the left and it works awesome. Sure, the bike is down once the shocks are swapped but there's still enuf room to run the lines, etc
Old Jan 24, 2017 | 11:09 AM
  #9936
cowboybob56's Avatar
cowboybob56
Default Common sense.
Common sense: is coming out to the garage to ride your freshly shod motorcycle and realize that you should install a new tire valve at least every other time you put on a new tire though considering the expense of a new tire stem, every time would be cheap insurance. Or how I've developed common sense.
Old Jan 24, 2017 | 02:26 PM
  #9937
470004's Avatar
470004
Installed a HD's LED headlight and had work done on the stock seat by MCC.
Old Jan 24, 2017 | 04:46 PM
  #9938
big papa AZ
Dropped primary oil, replaced "live to ride" derby cover, took a ride.
Old Jan 25, 2017 | 03:53 AM
  #9939
just plain john's Avatar
just plain john
Added a detatchable sissy bar
Old Jan 26, 2017 | 06:00 AM
  #9940
1HD1C's Avatar
1HD1C
finally completed JNR install took longer than normal and it wasn't just because of all the photos for the HOW TO for my site..
ended up they sent me wrong fittings for rushmore model so that took a few days
for correct fittings to arrive then we found that my cousins pitbull bike jack was not working, tried every trick pitbull said to try but it ended up being the jack itself so he had to order a new replacement.. after 5 days of waiting for the replacement I said screw it and decided to dig out my harbor freight yellow jack that was modified for my dyna... it worked GREAT!!
would I trust it to work on the bike lifted high up HELL NO due to the small foot print but for just swapping the shocks it was great..
