Primary Chain Slack - Advice Please
Old Apr 4, 2011 | 07:28 AM
mateo613's Avatar
mateo613
Default Primary Chain Slack - Advice Please
Hey Everyone,
I have a 2010 Ultra Limited with 8k miles on it, so that means I am 2k away from my next service. I just got off a 1,000 mile road trip this weekend and it seems that my primary chain has a lot of "slack" in it. Each time I take off and shift through the gears, I have to ease into the throttle, otherwise I will feel the lag between engine throttle and applied power. Is my assumption correct? Will I hurt it to drive it this way?
If so, given that I am not a wrench, is tightening the chain tension fairly easy? If so, can someone give me some pointers and give me any specs I might need. I don't currently have a service manual for the bike yet, however I do have one for my old 2005 Road King Classic.
Thanks,
Matthew
Old Apr 4, 2011 | 07:34 AM
bowa18's Avatar
bowa18
Originally Posted by mateo613
Hey Everyone,
Thanks,
Matthew
Your chain is adjusted with an automatic tensioner, you don't adjust it. I believe you're feeling slop from your compensating sprocket inside the primary. Do a search, you'll find more than you can read on this subject.
Old Apr 4, 2011 | 07:44 AM
mateo613's Avatar
mateo613
My compensator was just replaced with the SE version about 1,500 miles ago. Your comment is interesting, as I remember my mechanic measuring and tightening the chain on my 05 during each service, however this may have changed on my 10 model. Should I take my bike back to the dealer for "slack" that I am feeling?
Matthew
Old Apr 4, 2011 | 02:30 PM
cooper57M's Avatar
cooper57M
You could also be feeling the cush drive in the rear wheel, it has some slack to it too.
Old Apr 4, 2011 | 02:48 PM
davessworks's Avatar
davessworks
Are you still rinning a stock compensator? If so and you have done any performance work on your bike . . . well you know what's coming next. Also consider upgrading your clutch spring.
Old Apr 4, 2011 | 02:53 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
If you have slack in your primary, you will feel a lurch if you ease off of the throttle and then apply power.
I agree with cooper.... it could be the isolator that you are just not used to. It makes your newer bike have a luxury feeling drive train, instead of a Ford.
Link to the part
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Apr 4, 2011 | 03:05 PM
mateo613's Avatar
mateo613
I have the upgraded S/E compensator as of about 1,500 miles ago.
Old Apr 4, 2011 | 03:09 PM
mateo613's Avatar
mateo613
Link to the part
Yes, if I ease off the throttle and then apply throttle again, it will lurch and you can hear the slack in the primary. The dealer tells me that the primary chain has a tensioner and does not need manual adjustments. So, not real sure what the issue is, but I know for sure there is a lot of slack between power being applied and feeling the pull. Perhaps my primary chain does have slack in it, who knows. I will probably take it back to the dealer that installed the SE compensator.
Any additional thoughts?
Old Apr 4, 2011 | 03:14 PM
davessworks
"hear slack in primary" . . .
well if it really is your chain then the tensioner may be broken. If not then the compensator may be broken. Either way, and I did like the rear wheel isolator idea for a bit there, it isn't the isolator.
Old Apr 4, 2011 | 03:15 PM
shooter5074
I just read the part about the compensator upgrade.... the tech probably dorked up your chain adjuster when he had the primary apart.
