Primary Chain Slack - Advice Please
Old Apr 4, 2011 | 03:48 PM
mateo613's Avatar
mateo613
Originally Posted by shooter5074
I just read the part about the compensator upgrade.... the tech probably dorked up your chain adjuster when he had the primary apart.
I just scheduled an appointment for Thursday afternoon. I'll report back with the details. So, just wondering if I'm being too observant or is this really an issue? When you apply throttle is there lag, and then a "catch", or is it just like a car where it's solid all the way through.
Old Apr 4, 2011 | 04:09 PM
davessworks's Avatar
davessworks
clutch slip if I had to wager.
Old Apr 4, 2011 | 04:40 PM
badjustbad's Avatar
badjustbad
Hard to tell how much slack you are experiencing just from your description but if it is a lot, like the chain tensioner isn't doing anything, when you had the compensator replaced maybe the tech didn't remove the tie wrap. When you install the compensator you need to tie wrap the tensioner to remove the chain, clutch, etc. - it would be easy to overlook.
Old Apr 4, 2011 | 04:43 PM
davessworks
Nah - chain wouldn't slide over tie wrap too long before it cut thru. Of course if they used the lock tool instead of a tie wrap it could happen.
Old Apr 4, 2011 | 04:46 PM
davessworks
Put the bike in 1st gear, engine running. Front brake applied. Slowly let the clutch out slowly. What happens?
When does the front of the bike begin to dive? How far out is the clutch lever?
Now - with engine turned off rear brake applied only, 1st gear engaged, clutch out (ie not pulled in at lever). Move back and then forward. How far if at all can you move the bike?
dubepj
Jun 18, 2019 08:33 PM
Nnmharmon
Aug 24, 2014 11:08 AM
razehog
Mar 7, 2011 11:26 PM
dyna081
Mar 3, 2010 08:46 AM
rebman76
Aug 28, 2007 04:48 PM
