**free** anti security mod !!
Old Apr 5, 2011 | 08:35 AM
jamesroadking's Avatar
jamesroadking
Just wire in a (hidden) toggle switch in series with you exsisting kill switch or with the fuel pump 12 volt wire.
Old Apr 5, 2011 | 08:36 AM
'05Train's Avatar
'05Train
Originally Posted by viperr817
I myself like no security, to me the 5 second hassle of locking your ignition vs. being locked out of your bike by the security def outweighs having security. It has happened to me on both bikes I had security on, and it really sucks!
Locked out of your bike by the security?
You are aware that there's a bypass code you can enter on the bike if the fob battery dies, right?
Old Apr 5, 2011 | 08:42 AM
joflewbyu2's Avatar
joflewbyu2
More easily said then done especially if you have the run, tail & brake turn signals or the LEDs. The smart security system is tied into the turn signal module. I had problems using genuine HD RTB accessory and that is why I shy away from getting the sytem again.
Old Apr 5, 2011 | 09:03 AM
skratch's Avatar
skratch
i have the rtb, and i have not had any problems with the security. however, i do not have leds.
but i do practice the override procedure every couple of months, just to make sure. i can knock it out fast enough, no one has to wait on me to figure it out
Old Apr 5, 2011 | 09:05 AM
'05Train's Avatar
'05Train
LEDs and RBT. No issues with the security or the override procedure.
Old Apr 5, 2011 | 09:08 AM
ultrapacman's Avatar
ultrapacman
First, the factory smart security system is way too easy to defeat
I don't understand how the system is way too easy to defeat. With out the fob or knowing the code you can't start the bike.
Old Apr 5, 2011 | 10:17 AM
acftgrunt's Avatar
acftgrunt
Granted I know you looking for a "Free" set up. You probablly won't find one.
Here is a aftermarket system that will help you in your quest.
http://www.digitalguarddawg.com/index.html
chazzz
Jun 27, 2019 10:53 AM
13bob
Aug 7, 2014 09:38 AM
Bob H.
May 13, 2014 05:58 PM
rogersachs
Feb 20, 2014 12:17 PM
VaThumper
Jan 27, 2011 11:08 AM
