Amp Installation Upside Down???
Old Apr 6, 2011 | 05:24 PM
scottdoege's Avatar
scottdoege
Default Amp Installation Upside Down???
I am working on a custom install of a 4 channel lightbox amp (ARC) in my batwing fairing The amp has it's controls on the bottom as well as it's cooling fan. If I install it right side up, the cooling fan will be installed directly on top of the radio.
Am I correct that it does NOT matter which side is up? Electronic components don't care..... Right????
Thanks,
Scott
Old Apr 6, 2011 | 06:01 PM
streetglide_medic's Avatar
streetglide_medic
4th Gear
It shouldnt matter, I have installed tones of amps in my cars and trucks and have put them every which way except inside out and never had any issues.
Old Apr 6, 2011 | 06:07 PM
Tripleshot's Avatar
Tripleshot
Until you said it had a cooling fan, I was good for installing any way you can get it in. If the fan is for cooling, putting it on top of a heat source is counter productive. Now, mounting upside down is no issue unless fan bearings require a certain orientation. (I build PC's, Lots of fans do not have an issue) Take pics when your finished.
Old Apr 6, 2011 | 06:08 PM
scottdoege's Avatar
scottdoege
Awesome!! That's what I was looking for!!! Forum. Stay tuned for my custom cheap install for a 4 channel ARC clone install!!
Old Apr 6, 2011 | 06:15 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I'm on the edge of my seat.
Old Apr 6, 2011 | 06:21 PM
Geekzter's Avatar
Geekzter
<br />
<br />
Based on your comments from your other thread. I bought the same amp and in the process of installing it also. I will be install it upside down, with the fan on top. I have determined that only the RCA jacks need to be changed to wires to allow access due to the fairings bracket being in the way. At this time, without trimming the gauge brackets the outer fairings will not close. What modifications have you performed so far to make this amp fit.
hooter57
Audio Systems
Apr 22, 2018 01:14 PM
HogPilot54
2014-2024 Touring Models
May 19, 2015 02:47 PM
IzZy63
Jun 28, 2011 06:10 PM
jeffreyjames
Dec 15, 2010 05:14 PM
D34
Oct 23, 2009 05:25 PM
