Cruise control amber light
Old Apr 6, 2011 | 08:10 PM
2007rkjb's Avatar
2007rkjb
Default Cruise control amber light
Hi,
I have a new strange problem with my cruise control.
Bike is a 2007 FLHRC.
As soon as I turn the key switch to ignition, the amber cruise
light comes on, even with the cc switch on the handlebar set to off.
If I turn the keyswitch even the slightest bit back toward off ( counterclockwise ),
the light goes out.
Can't figure this out.
Any ideas.
Thanks in advance,
Jake
Old Apr 6, 2011 | 08:13 PM
Lass7711's Avatar
Lass7711
Does the cruise work with the switch off? If so, it might be a bad CC switch.
Old Apr 6, 2011 | 08:18 PM
FX4's Avatar
FX4
The light comes on the switch is bad. It's either stuck closed or the LED in the switch has a path to ground.
Old Apr 6, 2011 | 09:01 PM
DynaStorm's Avatar
DynaStorm
ummm...just to be sure I'm following correctly....the handlebar switch only 'sets' the cruise...if the switch on fairing cap is flipped, the cruise is 'active', waiting for you to set while you get to speed..so.......hence....if the rocker switch at fairing is flipped, orange light is ALWAYS on
Old Apr 6, 2011 | 10:05 PM
2007rkjb's Avatar
2007rkjb
FX4,
Do you mean the cc switch on the handlebar is stuck or grounding ?
MURPHCC1
Electrical/Lighting/Alarm
11
Oct 15, 2019 01:36 PM
Bubba Zanetti
Oct 2, 2017 10:30 AM
dr_ductwork
May 13, 2016 11:47 AM
okieriverboy
Mar 7, 2011 09:41 PM
jcbpa
Aug 19, 2008 10:07 PM
