dead lights
Old Apr 6, 2011 | 10:48 PM
hiebie's Avatar
hiebie
2nd Gear
Lightbulb dead lights
I have a 2000 electra classic and dilemma is my turn signals and brake light stopped working for no reason that I can find. I have checked all my fuses and relays and they all seem to be fine. Any ideas or suggestions would be greatly appreciated,
Old Apr 6, 2011 | 11:06 PM
angelrod's Avatar
angelrod
did you lower your rear end ?If you do check, underneath you fender it could be some broken wires in there, this common when using those lowering kits . I've seen so many of those . if not check all connections. also if you got turn brake park module .those thing also go bad,,good luck
Old Apr 7, 2011 | 08:06 AM
munch34m's Avatar
munch34m
Ignition switch? I'm purely guessing
Old Apr 7, 2011 | 08:10 AM
mastery's Avatar
mastery
Did you replace the fuse? I know you checked them...but sometimes they break in a way that's hard to see. I've had them break in the thick part under the thicker plastic that's not easy to catch.
Old Apr 7, 2011 | 01:24 PM
hiebie's Avatar
hiebie
2nd Gear
All great ideas thanx a ton guys I'll let you know if anything works. Peace and ride safe.
Old Apr 7, 2011 | 02:30 PM
FDHOG's Avatar
FDHOG
Also check the forward wiring harness for the lights. That was the cause of my problems.
Old Apr 7, 2011 | 09:00 PM
hiebie's Avatar
hiebie
2nd Gear
Default lights are fixed
Miastery:
Thanx for your help on the fuse issue. I went back and checked the fuses again and with the help of a meter I found the culprate. I looked real close and still can't see where it was burnt but it was and is subject to a well placed hammer (lol) .... Thanx again bro ride safe and peace :-)
Old Apr 7, 2011 | 09:02 PM
hiebie's Avatar
hiebie
2nd Gear
Thanx for all the help with my light issue. All is fixed and working good.
Mikula
Electrical/Lighting/Alarm
Nov 10, 2014 09:06 PM
ronbeejer
Mar 9, 2014 08:20 PM
steelerdude1
Mar 18, 2012 02:47 PM
recon_sct
May 18, 2009 11:37 PM
SamStone
Jun 25, 2006 08:22 PM
