Auto compression relese
Old Apr 9, 2011 | 06:10 PM
thumper05's Avatar
thumper05
Exclamation Auto compression relese
Does any one know if the 08 ultras are wired for ACR? there is a wire connection under the fuel tank that isnt used, was wondering because im wnating compression releases.
Old Apr 9, 2011 | 06:33 PM
user 8373900's Avatar
user 8373900
Nope.
Old Apr 9, 2011 | 06:47 PM
CigarCritic's Avatar
CigarCritic
Link: ACR Wiring Harness for 2008
I was going to get it done on my 2008 but my dealer did not want to invest in the tool at the time.
Old Apr 9, 2011 | 06:48 PM
vbx07's Avatar
vbx07
I have an 07 sg with auto comp release. Plug for harness was already there from the factory.
Old Apr 9, 2011 | 07:17 PM
131tman's Avatar
131tman
I'm wanting compression releases.
http://www.harley-davidson.com/en_US...ts/-J04654.pdf
Old Apr 10, 2011 | 05:23 AM
neverhme's Avatar
neverhme
my 2010 ultra had the plug ends mounted to a plastic bracket on the throttle body, if you remove the air cleaner you should be able to see if there installed. I took my harness all apart searching for the wires, assumed the s/e book was right and I needed the harness, wasted about 3 hrs on it, owell I have a harness if you need one, and the directions, just used the zip ties from it.
HD_Doobie
2014-2024 Touring Models
115
Sep 2, 2014 06:16 AM
WIHD55
Dec 23, 2012 02:19 PM
mars636
Nov 27, 2011 03:26 PM
cadonaldson
Jun 8, 2008 11:29 AM
Bluetick
Apr 20, 2008 05:52 PM
