LED Bulbs!
Old Apr 10, 2011 | 08:05 AM
UltraDune's Avatar
UltraDune
Default LED Bulbs!
Looking to replace my turn signal bulbs to LEDS as well as the brake light. Any suggestions for the best on-line deal? I have seen them as low as $5.00 all the way to $40.00. Is there really any difference? Thanks for the info.
Old Apr 10, 2011 | 08:12 AM
streetglide44's Avatar
streetglide44
Mine are from custom dynamics. Lifetime warranty, super service.
Old Apr 10, 2011 | 08:33 AM
handsomeboy1's Avatar
handsomeboy1
I also got mine from custom dynamics. Was less than 200 for fronts and rears. They look great.
Old Apr 10, 2011 | 09:11 AM
UltraDune's Avatar
UltraDune
Thanks for the info. Are the inserts from them worth the price difference as just doing bulbs? I have found the bulbs for around $22.00. Are they as bright as they claim? Thanks again.
Old Apr 10, 2011 | 09:16 AM
streetglide44
Very bright. Guys behind me hate them. Makes me like them even more. "Can you see me now".
Old Apr 10, 2011 | 09:19 AM
GotHog?'s Avatar
GotHog?
You might check into Badlands. I have them and love them, got the whole set up front, rears, and brake with the module fit is great and a very good quality.
Old Apr 10, 2011 | 09:35 AM
'05Train's Avatar
'05Train
Custom Dynamics all the way. I've replaced all my bulbs (other than the Tour-Pak) with LEDs from them, and they make a huge difference in visibility.
Old Apr 10, 2011 | 10:14 AM
JoshuaCannon's Avatar
JoshuaCannon
Custom Dynamics all the way, Awesome product!! I just got the fendertips signals and rear brake!
Old Apr 10, 2011 | 11:13 AM
Stang951's Avatar
Stang951
Custom Dynamics. HANDS DOWN.......Their warranty is the best in the market. I have had several problems with diodes on boards, LED's etc and they have helped through all problems. No hassles, only great service.
Old Apr 10, 2011 | 11:46 AM
fabrik8r's Avatar
fabrik8r
I use 1156/1157 LED bulds for automobiles, very bright and way cheaper than anything "marketed" for cycles. A lot of companies selling competitively priced automotive LEDs out there. I used a company called VLEDS, they have extreemly bright bulbs. http://www.v-leds.com/Exterior-LED/P...viewsTabAnchor look closely at where the metal base and the fiber meet, the design of the bulb base require that I carefully file down outer edge of the lower circuit card the LEDs are actually affixed to, they have been working perfectly for over 2 years now. Word of caution, the HD light sockets are very tight fitting to closely acommodate traditional incadescent bulbs look for bulb bases that have the additionl step in them if possible to eliminate the need for any modification. Truth be told I did have to ruin one to figure it out, don't dress them up on a grinder, gets too hot too fast and will melt the epoxy that holds the light assembly together, not a warranty issue. It only takes a couple minutes to clean them up with a small file.
