Throttle-NO response-Please help
Old Apr 11, 2011 | 09:51 AM
viperr817's Avatar
viperr817
Tbw on an 06??? Thought tbw didn't come out till 08....
Old Apr 11, 2011 | 10:06 AM
stro1965's Avatar
stro1965
Exactly.
Old Apr 11, 2011 | 10:08 AM
user 8373900's Avatar
user 8373900
Originally Posted by Kesean
Twist grip sensor is what it sounds like.
>>'06 FHLTCUSE, 103 cu inch - stock.<< cables...
Old Apr 11, 2011 | 10:43 AM
Silverearl's Avatar
Silverearl
Two things to check. One is the throttle cables first. Wait you said the motor revs. That being the case check the clutch cable and make sure it is releasing like it is supposed to. If you do an oil change and remove the clutch cover you will see if the clutch is engaging like it should.
Old Apr 14, 2011 | 11:46 AM
stro1965's Avatar
stro1965
What did you ever find wrong?
TSD
Jul 19, 2020 08:09 PM
Texas_Grim
Feb 18, 2015 04:52 PM
SHAKEME
Aug 7, 2011 08:08 AM
t059736
Screamin Eagle CVO Models
Apr 15, 2011 01:05 AM
dynalowride
Jan 28, 2007 07:03 PM
