Excessive Heat
Old Apr 11, 2011 | 02:32 PM
kyloon's Avatar
kyloon
Default Excessive Heat
Just recently had some mods done to my 2010 StreetGlide, had a LA Choppers Air cleaner, CAT removed, Power Commander V, and had the head pipes wrapped in heat wrap instead of going with heat shields. Yesterday was my first major ride since the additions and I'm experiencing extreme heat and a drop in my mpg. I thought removing the CAT would help with the heat issue and adding the power commander would possibly help the mpg but its opposite with both. What could be the cause or the fix to this issue?
Old Apr 11, 2011 | 02:35 PM
RockerMike's Avatar
RockerMike
Sounds like you need a better map on the PCV. If you got it from Fuel Moto give them a call.
Old Apr 11, 2011 | 02:37 PM
kyloon's Avatar
kyloon
RockerMike, thanks..thats what I was thinking but the bike shop is closed today so I wasnt able to speak to them about it.
Old Apr 11, 2011 | 02:53 PM
sg2007's Avatar
sg2007
What MPGs are you getting on your bike, I've got a 2010 Streetglide with these mods ( stock 2-1-2, with cat removed, Dyno tuned mufflers and PCV from Fuelmoto) been running this way for 2 months. Very little heat,but my MPGs are not higher than 33. Tried the last two maps from Keith with no change maybe you're set up might be better with a new map from FM.
Old Apr 11, 2011 | 03:13 PM
kyloon's Avatar
kyloon
My setup is the 2in1 with cat removed, Rinehart 4in, then the LA Chopper air cleaner with the PCV and after the first ride I am guessing 30-35mpg with very high heat. Based on my memory from last year I was getting around 250 per tank of gas on rides.
Reaper22
Sep 25, 2012 12:45 PM
100thRK
Fuel Moto / Jackpot Mufflers
Jul 19, 2010 12:04 PM
2WheelGlider
Jun 7, 2010 05:50 PM
Ferggie
Sep 17, 2009 10:08 PM
hdflyer76
Jun 12, 2009 10:40 PM
