Lube on TBW grip
Old Apr 11, 2011 | 04:53 PM
masterblaster's Avatar
masterblaster
Default Lube on TBW grip
My TBW grip seems to be harder to turn than it was when new is tehre a lube point on these grips I am missing ?
Old Apr 11, 2011 | 05:00 PM
Potato_Potato's Avatar
Potato_Potato
I don't think it calls for lube. I would uninstall and reinstall leaving a little play on the lateral movement. It may be that it shifted a little and is binding. If I felt it needed lubing I would use only a drop of gun oil or a dry type lube and limit its use to only the friction points.
Old Apr 11, 2011 | 05:01 PM
twistr's Avatar
twistr
Not trying to be a wise guy...but make sure you have the proper grip on the correct side of the handle bars...a friend made this mistake and his he thought the throttle grip was hard too..when I looked at it, it was on the wrong side...once switch it worked like a charm.
Old Apr 11, 2011 | 05:34 PM
masterblaster
Yeah thx but these are the stock grips, I am one the few that lokes the stockers.
Old Apr 11, 2011 | 05:48 PM
lp's Avatar
lp
I use red axle grease on the part that is retained by clam shell.
Now I ask... how long do you think it took me to actually respond to this post in an adult like manner avoiding sexual puns? = a long time.
Some early failures:
I grease my grip with red axle grease around the lip.
I lube the lip with grease before putting it in the clam shell.
Sometimes the clam shell is tight and you have to lube the ridge near the end of the grip.
Work the tip of the grip back and forth in the clam shell with red axle grease to loosen it up.
Lube Just the tip, just the tip!
See...
lp
Old Apr 11, 2011 | 06:37 PM
Sam2010's Avatar
Sam2010
Yea I used a thin film of wheel bearing grease on mine. AFTER I put it on dry and rode it 1k miles with it sticking.
Old Apr 11, 2011 | 07:29 PM
Uncle Larry's Avatar
Uncle Larry
You are one sick puppy .... and that's what I like about this place .... to hell with all of the political correct BS. You da man "lp"
Old Apr 11, 2011 | 07:32 PM
masterblaster
hehehe funny lp, thanks for tha laugh. We already have one actual Sick Puppy on the forum, I know him and he is a sick pup. look him up.
Old Apr 11, 2011 | 11:22 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
I put my stock grips back on about a month ago and I used silicone spray to lubricate the TBW grip.
Old Apr 12, 2011 | 01:44 AM
emwolb's Avatar
emwolb
you're from south florida, go to a "fun" style massage parlor, they'll likely lube it for you. by the way, watch out for the sign in the door when it says "closed today, beat it" sorry man, i just couldn't help it.
