While I was doing the "Big Cleanup" on my Road King,finally got around to checking the front brakes since I was replacing the tire..Had always thought that one of the rotors were warped since it would pulse when I used the front brake,and also had a bad rotor on my 06 RK..
Took a look at the pads and did not look bad at all,so I sprayed the calipers real well with brake cleaner grabbing the lever and extending the pistons and pushing them back in.. Put everything back together and was able to put a few hundred miles on it..Everything is working as it should.
Cleaning the caliper pistons will make a big difference in brake performance.
I use an old set of pads put them in the caliper,and squeeze the lever until the pistons are out almost all of the way,and hose them out with brake clean.
