Detachable Backrest
Old Aug 18, 2005 | 11:26 PM
toadmanor's Avatar
toadmanor
Default RE: Detachable Backrest
ericdata,
Thanks that was it. I just needed to loosen a couple of those other fasteners and all worked fine.
Old Aug 18, 2005 | 11:55 PM
NH_FLTRI's Avatar
NH_FLTRI
Have you guys found that people steal your QD items? I never thought about that issue but i suppose there are some losers out there..........
ORIGINAL: Grover
I have an 05 RK with the QD Backrest and QD luggage rack. Each uses separate mounts. There are two mounting points for each on each side for a total of 8 mounting places. The front of each accessory has a slot to slide on the leading mount and then it rotates down into place. There is a notched latch that rotates around the rear mount and locks into place.
Worried about security for your attachments? Harley sells a lock that secures your QD items to the bike. Part # 46063-98 singly or 46106-00 for two keyed alike.
Old Aug 19, 2005 | 12:33 AM
RKRick's Avatar
RKRick
ORIGINAL: cbrunson
...Wait ‘til you start looking at the instructions. I ended up turning all four sets of instructions to the parts assembly pictures to see how it all fits together. It’s a pretty easy install, just goofy instructions.
This was my exact same experience.. just used the assy. pictures from the sissy bar kit.
Old Aug 19, 2005 | 01:28 AM
ericdata's Avatar
ericdata
Glad I can be of help Toadmanor.
Nobody better mess with my bike, cuz if I catch them they're dead.
Support your local 81!
Old Aug 19, 2005 | 09:23 AM
toadmanor's Avatar
toadmanor
i have never heard of anyone messing with a QD.
Since mine is new i have no experience.
Harley does sell a lock for it i know.
Old Aug 19, 2005 | 11:59 AM
Grover's Avatar
Grover
Administrator Emeritus
I have the QD backrest and luggage rack. I have had no problems with anyone bothereng anything on my bike.
I spent a day at the beech in Ventura, hung the helmets on the highway pegs and worried about them. Came back and they were still there. I have since bought a helmet lock.
I have not bought the QD locks yet, but I intend to.
Best to keep the honest people honest.
Old Aug 22, 2005 | 05:58 PM
tgoulart's Avatar
tgoulart
6th Gear
Do you find that your saddle bags hit these new bolt heads when you open the bag, marring the top of the bags? Mine is worse when the backrest is installed and the release button almost doesn't allow the bag to open.
I should note I have an '05 RK Classic with the leather bags.
Old Aug 22, 2005 | 06:47 PM
Grover's Avatar
Grover
I have had no problem with interference with either set of QD mounts.
The trick is to lift the cover up and pull up and out at the same time.
The latch will disengage the striker and allow the lid to move away from the bolts.
Old Aug 22, 2005 | 06:57 PM
cbrunson's Avatar
cbrunson
ORIGINAL: tgoulart
Did you put the 9/16” long spacers on the rear bag mount bracket? I tried it without them and had to put them in for that reason.
Old Aug 22, 2005 | 07:03 PM
Blue SOG's Avatar
Blue SOG
ORIGINAL: ericdata
I find it odd that you "Support your local 81!" yet don't want anyone messing with (stealing) your bike or stuff...
[sm=dontgetit.gif]
[sm=wakeup.gif]
